#301 |
I'll buy a pair. I'll use them somewhere....
Too good a price to pass up!
Happy to serve. |
#302 |
Are they thin enough to get the grips back on easily enough?
I assume you glue the heaters to the bars/throttle tube and do not glue the grips on, just dlide them into place?
Happy to serve. |
#303 |
wow those look like an awesome option for cold weather riding over the $150 heat grips I keep looking at.
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !! ![]() |
#304 |
I also like that it seems as if you can replace the grips as much as you need to and save the heaters.
Happy to serve. |
#305 | |
![]() ![]() Spud ![]()
#306 | |
![]() Spud ![]()
#307 | |
![]() Spud ![]()
#308 |
A while back I bought a PWM (Pulse Width Modulator) device to substitute for the 10-ohm resistor which controlled the "low" setting on my Tusk Grip Heaters. Several days ago I installed the device, and attached it with velcro to the inside of my headlight shroud.
![]() ![]() I wired the PWM device in the the following method, using a DPCO (Double-pole, Double-throw, Center Off) switch from Radio Shack. ![]() I'm pleased to report the PWM device works great. It's nice to be able to modify the heat output of the "low" setting, and not waste a lot of power through the 10-ohm resistor. ![]() ![]() Spud ![]()
#309 |
Does it act like a rheostat?
#310 | |
![]() ![]() http://en.wikipedia.org/wiki/Pulse-width_modulation I bought this PWM device on eBay for $5.69, delivered. ![]() http://www.ebay.com/itm/DC-5V-24V-4A...item2319c1479e Spud ![]()
#311 |
Brilliant! Thanks for the links.
#312 |
You're welcome.
#313 |
I'm impressed Spud!
![]() You copied the wiring diagram from a Medtronics pacemaker? ![]()
Happy to serve. |
#314 | |
![]() Spud ![]()
#315 |
Just joking as I was impressed with the precision and complexity of your wiring diagram.
Happy to serve. |
