Old 08-17-2018, 12:36 PM   #286
Love the 300 kit. As stated previously, made the bike much more friendly. Far less of a two stroke power band.
After I finish another car project I'm currently on, I'd be very interested in the front brake kit and water bottle.
Old 08-19-2018, 10:19 AM   #287
NZ, these changes started in Jan 2017. Is there any indication (by engine number?) that tells old from new? In my case I have a replacement engine so the date of bike manufacture does not help.
Old 08-19-2018, 03:25 PM   #288
OK, thanks for your help. My Chinese is a bit rusty.
Old 08-19-2018, 08:58 PM   #289
Juanro   Juanro is offline
Juanro's Avatar
The counterbalance shaft part might be about this:
(Up, older version, down, newer)
Old 08-20-2018, 10:15 AM   #290
I can see that the internal ribbing changed, also a retainer on the counterbalance shaft bearing. I do not see a different number of bolts holding the cases together. Thus, I cannot see how one can determine which engine is the 'improved' one without tearing into the cases. Note that the two photos are taken from a slightly different angle, hiding one of the bolt holes in one of the photos. All this is moot until one needs a replacement internal part where there might be a different part number. As an aside, I think it's good that Zongshen makes small changes as needed to improve what appears to be a very well built engine.
Old 08-20-2018, 11:28 AM   #291
I just think it's neat that Zong is improving and updating. It proves that they're serious about this and not just pumping out a motor to flood the market, then walk away.
Old 08-21-2018, 09:33 AM   #292
NZ, your photos might show darn near anything but I can't tell because they are too small. My observations are based on the much better photo provided by Juarno, where the engine cases appear to have the same bolt pattern. If the outer cover is different that would indeed make it possible to spot the improved engine without splitting the cases.
Old 08-21-2018, 12:22 PM   #293
NzBrakelathes's Avatar
Sorry that my “free” information that was translated from the engine wholesaler here in China and not available in perfect English doesn’t meet for easy reading
Sorry I do not have the answers you want or that my work has no value to people etc
I’ll withdraw my post that shows and stated that this is all I know and nothing more.
Seems people want things on a platter and handed to them today! Not just here but other places too.
Sorry that I try n provided for my family and info for bike owners and try sell knowledge based components worldwide
How I rude of me
Old 08-23-2018, 10:26 AM   #294
Huck369   Huck369 is offline
Huck369's Avatar
Finally got around to getting my kit installed, what is the actual CC's with the kit added, I recall seeing it somewhere, but can't find it now....
I know it's not 300cc's, but can't remember what it actually was....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 08-23-2018, 11:26 AM   #295
ChondaChondaChonda   ChondaChondaChonda is offline
ChondaChondaChonda's Avatar
283cc
1993 CR125 powered by Zongshen 223cc OHC
2̶0̶1̶6̶ ̶L̶X̶R̶ ̶2̶5̶0̶ ̶E̶F̶I̶ ̶ Sold
2018 GPX Moto FSE250R
1993 Fantic Key-Roo 250
Old 08-23-2018, 11:27 AM   #296
Juanro's Avatar
This is original NC250
Bore x Stroke : 77×53.6mm
With the "300" kit, we're getting bore = 82mm, and stroke is the same.
So if my math is right, this is 283cc, a 13.2% increase
Old 08-23-2018, 11:31 AM   #297
Juanro's Avatar
My own kit is about to come the 1000km mark since installed
Love, really love the added torque, seems much more than 13% increase.
Every road I know, I can ride now a gear higher (and thus about 1K / 1,5K rpm lower)
Cruise speed is about the same, but no need to downshift overpassing slow trucks. Recovery in 6th from 5K to 7K rpm is really fast and smooth
Also engine sounds much fuller and bigger.
Old 08-23-2018, 12:02 PM   #298
I came up with the same number. What I find interesting is that the original displacement is 249.6cc; it's an actual 250cc. So often, motorcycle manufacturers will round up the displacement, like Yamaha did with the second generation SR250 (which was only 239cc).
Old 08-23-2018, 12:20 PM   #299
Huck369's Avatar
Originally Posted by ChondaChondaChonda View Post
283cc
Thanks!!
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 08-23-2018, 04:15 PM   #300
For all it’s worth I may have found a used EFI kit from the Kayo K6
If you still feel the need etc do send a PM and I can look closer at things for you
