#16 |
Maybe my battery had an internal short but the guy who load tested it said it had 9 volts with the load on it. I tested it with a volt meter and it had 12.4 volts.
Like I said earlier I could kick start the Q and it would idle but bog and die if I twisted the throttle even after warm up. |
#17 | ||
#18 |
barnone do you have a wiring diagram for your bike you could post on here?
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
#19 |
I haven't had the chance to or needed to study the wiring doagram on my Q yet, but I have a Yamaha Rd400 and if the rear brake light burnt out the bike would not run until you replaced it. So who knows if there is an open circuit like a guage light or turn signal being out causing the problem
Bikes: Yamaha 1974 Yz125a, Yamaha 1974 Sc500, Yamaha 1977 Rd400, Yamaha 1978 Yz125, 1988 Harley Davidson Xlh 883, 2006 Ktm 450 smr, Ekeleton 2006 Beast 200cc the worst bike I have ever owned |
#20 |
I can attest to what barnone is saying. I had to replace my battery also on my XF200. It's two years old. Of course, I don't know how long the battery sat in the bike before I bought it. Anyway, I put it back in this year to start and no go. It did the same as bar's when I kick started it. It would idle but bog when throttling. I didn't try it with the battery out, however. I wonder if that would make a difference. There is a wiring diagram in both the english version manual from Andrew and the portuguese one.
#21 |
I'd be worried that running with no battery at all would take out the CDI.
#22 | |
Happy to serve. |
#23 |
Stumbled upon some more info. According to DrAtv, engines with a DC CDI must have a battery to generate spark, whereas the AC version can run without a battery. http://www.dratv.com/distty.html
#24 |
I put many, many hours on my Hondoid with no battery at all connected in. Never gave me any trouble besides a sore instep.
Eventually got tired of kicking and bought a new battery. |
#25 |
Bring a spare "cap" will solves those ??? .
http://translate.google.com/translat...thorid%3D75082 |
