04-19-2011, 02:03 PM | #16 |
I believe they are all patterned on the crf50 xr50 type mounts. The 50/70 are the same. The 90 is different. Not sure on the larger atc 110/125 engines. I think they are like the 90.
AFAIK all the chinese clones are designed to fit the 50/70 pattern.
04-19-2011, 02:10 PM | #17 | |
04-19-2011, 02:38 PM | #18 |
TC, the more I look, the more I appreciate your adapter. How did you copy the profile of the China engine?
04-19-2011, 04:25 PM | #19 |
Its been so long I forgot exactly how I built it but I started with two flat pieces on top and drilled the holes and set the cross tubes then went from there.
It was an endless test fit-grind...test fit-grind until it fit right. But basically I had to make the mount fit the frame first then fit the engine to the new mount but I had to make sure to leave enough space to actually get the engine to fit up in the mount as I was building it. I was using a trans jack to support and lift the engine so it was easy to do. Heres a better picture of the mount on top of the engine The frame has been stripped down for the most part, I just have to finish sanding it and then I can paint it and start the reassembly but I really want to get new rims for it but doubt I'll be able to. Here a picture of it up on the work table. I really wanted the fully auto 50cc engine but I got a great deal on two of the 50cc semi-auto engines I just grabbed them.(both for around $140-NIB) |
04-19-2011, 04:50 PM | #20 |
Real nice work. Did you do the seat also? Have you cinsidered a media blaster? Might save a lot of time and yield an excellent result.
Happy to serve. |
04-19-2011, 05:00 PM | #21 |
if you made a template for those brackets you could probably sell them. im sure there alot of people with the old hondas that would love to get them going again. this would be a great option.
in my opinion.
my help may not be the best but it is free+-Seek ye first the kingdom of GOD |
04-19-2011, 05:13 PM | #22 |
I bought the seat its just a copy but its nice.
I have a blast cabinet and a small cheap portable blaster that works OK, I'll use the portable to get the places that are hard to reach.The frame is mostly stripped clean right now I'd bet a good weekend of working on it and it would be ready for paint but no hurrys around here with this cold damp weather. I used a chemical strip to get most of the heavy stuff then sanded and wire wheeled the last bit but I never got it all done with the way things turned out and now its all mixed up and buried in a shed and the garage. No templates but they are not to hard to make although copying the one I made would be much easier than remaking one from scratch. |
04-19-2011, 09:11 PM | #23 |
Thanks for the detail; I can see now how the original motor used three mounts, vs. two on the China motor. That gives me some ideas for the old YB100 I have.
