Old 04-08-2007, 05:39 PM   #16
blimpman   blimpman is offline
Re: GY-5 front winkers
Here is what I did... Others here have done the same. Gonna do the rear ones soon.
http://www.chinariders.net/modules.p...532&highlight=
Originally Posted by jeffhei
Has anyone changed the location of their front winkers? I don't like the way they are mounted to the handle bars. Does anyone have any ideas: brackets, routing the wires?
The destination is merely a by-product of the journey.
'06 KLR650 '06 XT225 '92 XT225 Serow
( MBD.... Multiple Bike Disease...)
Old 04-08-2007, 06:06 PM   #17
jeffhei   jeffhei is offline
I had to change the way the choke was mounted on the left side.
The right side was not a problem.
Looks better than it was
2006 Lifan LF200GY-5
Old 04-08-2007, 06:26 PM   #18
Jim   Jim is offline
Looks good, I think they should work good there
Old 04-08-2007, 07:32 PM   #19
pumpkin   pumpkin is offline
here is the rear
06 american lifan 200 gy-5
Old 04-10-2007, 12:03 AM   #20
they also have hand guards with winkers built in if you want a cleaner look but i wanted the front to match the rear
Old 04-10-2007, 12:15 AM   #21
Jim   Jim is offline
jeffhei, yeah I just noticed today my dads choke is mounted the other way around aswell.
Old 04-10-2007, 11:53 PM   #22
Savage   Savage is offline
Do you guys know if these would work? (electrically speaking)
Or do the measurements just sound way too big?
Copy and paste this # in ebay.
200098550028
Old 04-11-2007, 04:00 AM   #23
ejcycles's Avatar
Savage
Auction; http://cgi.ebay.com/ebaymotors/ws/eB...romZR40QQfviZ1
Sure they will work, you just have to watch the watts for the bulb. Changing the bulb wattage will change how the turn signals operate {slower or faster} depending if the wattage is higher or lower. You may have to change the bulbs in the turn signals you purchase or the flasher relay. I hope this helps.
Bruce
Old 04-12-2007, 10:25 PM   #24
Helps, but opens another question. :wink:
What watts work for our "winkers"? What's the safe range?
Kinda off topic, but not too bad: I think the headlamp is 35W, how much brighter one can I put in there and still be OK?
Thanks all!
Old 04-13-2007, 09:30 AM   #25
ejcycles's Avatar
It's not what's a safe range, it has to do with what you buy and what watt bulb is in the ones you buy. All of the aftermarket lights on the market {all of them} have a certain wattage/candlepower bulb in them because the bulb is so close to the plastic lens. To high of a wattage bulb in a lot of these will melt the plastic. The higher the wattage/candlepower the hotter the bulb itself gets. You can put a higher wattage/candlepower bulb in some because the plastic cover is further away from the bulb, but be careful. You may also have to change the flasher relay due to this also. There are no books that have recommendations on this you just have to figure it out for yourself, as I do.
Bruce
Old 04-13-2007, 09:43 AM   #26
Thanks all!
I run the 45W that's listed in the parts thread at the top and it's been fine for almost 3000 miles.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
