08-05-2010, 11:43 AM | #16 | |
Thanks for the vids Cal.
08-05-2010, 03:23 PM | #17 | ||
08-05-2010, 04:33 PM | #18 | |||
Spud 8O
08-05-2010, 04:37 PM | #19 |
hey, at least his right knee had protection.
08-06-2010, 09:16 PM | #20 | |
Looked to be a bit close to the white line and he wanted to move left. Should'a pushed on the left bar. To quote my MSF instructor, "If you think you're into a curve too hot and you ain't dragging parts, you can ride it out. Grab the brakes or try to turn toward the curve and you go down." Bill |
08-07-2010, 12:35 AM | #21 |
That's the kind of concept that's very difficult to explain to a new rider. If you have enough forward momentum (not even in a turn) and you apply slight pressure to the right handgrip, you'll go right. It's totally counter-intuitive.
As I understand it, it's because the force that is applied to a rotating mass or gyro is realized 90 degrees from point of input. Or something like that. :wink:
08-07-2010, 01:03 AM | #22 |
This steering technique is called countersteering. Once you are riding fast enough for centrifugal force to take effect, you must steer the motorcycle using countersteering. The technique is simple. To turn left, press forward on the left handlebar. To turn right, press forward on the right handlebar. Press left, and go left. Press right, and go right.
This technique is very easy to use, but it is more difficult to explain how it works. Because of the forward rake of the front wheel, when you press left, the contact patch of the front wheel shifts to the left. This causes the motorcycle to lean to the left. The leftward lean initiates a left turn. However, once the left turn begins, centrifugal force, and the forward motion of the motorcycle cause the contact patch of the front wheel to align itself once more, and the front wheel actually ends up pointing into the curve. Although you might not realize it, you are constantly making minor adjustments to maintain this delicate equilibrium every time you countersteer. This entire process is thoroughly explained in the excellent book, More Proficient Motorcycling, Mastering the Ride, by David L. Hough. Spud
08-07-2010, 01:16 AM | #23 |
Thanks Spud, I learned something new. I thought that counter steering was the act of locking the bars in a high speed turn in the opposite direction of the turn, just like flat track racers.
