05-13-2010, 04:17 PM | #16 |
I've been thinking about the pre-load thing since I posted this on MCM;
http://www.mychinamoto.com/forums/sh...ight=david3921 If you look at the middle picture of post #4 you can see the pipes that are under the cap. These are under tension and need to be pushed down to remove the retaining clips (post #3). I would think that some PVC tubing of the same diameter could be installed between the end of the pipe and the retaining clip to increase pre-load. They could be made in 1" increments to test out. They are very easy to replace...if done one fork at a time as mentioned above. |
05-13-2010, 07:32 PM | #17 |
Ok I took the top caps off and directly under it is a long skinny hollow metal pipe.I measured it at 1" and bought some pcv pipe ( they told me it is shed 40 pipe ) .
The sales guy was like" won't it just shatter??" but hey he's a plumer..LOL Ok so I just need to cut 1"spacer and place it under the cap between the metal tube and the cap OR should I measure the metal tube and make the pvc pipe one inch longer and put that it ( removing the metal tube) ?? |
05-14-2010, 08:30 AM | #18 |
Keep it simple and just add a 1 inch piece. I would would just cut a longer piece to try if I wanted more than a inch.
Are you changing the oil? |
05-14-2010, 03:40 PM | #19 |
I want to change the oil weight also but first I am looking for some instructions on the process and what the factory oil amount is.
05-14-2010, 04:37 PM | #20 |
No real answer there. Best bet is drain what is in there and measure the amount.
05-15-2010, 09:06 AM | #21 |
Did we determine whether ken had conventional forks or USD?
05-15-2010, 12:50 PM | #22 |
conventional forks and dual rear coil over shocks on the rear.
05-15-2010, 11:33 PM | #23 |
Got spacers in and it is a bit better.Will be draining oil and refilling with new oil.after the weekend
Thanks guys |
05-16-2010, 12:04 AM | #24 | |
