View Poll Results: What kind of work do you do?
Professional (Doctor, Lawyer, etc) 6 18.18%
Mechanical 6 18.18%
Technical 5 15.15%
Computer - Software 2 6.06%
Computer - Hardware/networking 4 12.12%
Sales 2 6.06%
Self-Employed 4 12.12%
Service Industry 1 3.03%
Stay at home parent 0 0%
other 3 9.09%
Voters: 33. You may not vote on this poll
Old 09-13-2006, 01:30 PM   #16
DeethDaa   DeethDaa is offline
Re: Stiff rear suspension
Originally Posted by ImEazy
That's cool. Mine isn't set up like that. I got a 2005 cheap ebay clone. Non adjustable shock and swinarm mount.
Yeah, sorry. I see what you mean. But if the rear suspension is really bad, you do have acres of room to modify the bottom shock swinging-arm mount position. You could relatively easily move it forward and down to retain the same ride height, but enabling the swinging arm to have a greater mechanical advantage over the shock. You could do this with a plate which bolts between the original swinging-arm shock mount at one end, and has a new shock mount at the other, as well as a means of stopping it rotating (possibly a bolt through the swinging-arm cross member. This would be a cheap fix I would use if the rear suspension was as bad as mine was initally, but I had your mounts. Just a thought.
Old 09-13-2006, 02:22 PM   #17
ImEazy   ImEazy is offline
The best way I could fix things is to gain some weight. laughs. Seriously though I think I may have found a way with an air adjustable shock. Just trying to figure out a way of getting the funds. Will let ya know...
2000 MZ Baghira
