#16 |
good question about 4th gear, but i know i was in 5th gear.
about the plug, i bought two new plugs the other day but the bike runs to good to have a problem with stock one i believe. yea i might be asking to much of this bike on that hill at 55 right now. i bought it to ride to work (about 5 miles at 55 to 60 then 3 miles in town) and then do a little trail ridding ever so often. i have one pretty good size hill to climb about 1/4 mile long that i have to give a lot of throttle to in 5th. i think with a few mods and that 14 tooth gear i will get there. oh yea it should do a little better after a few more miles also. i just installed a tach i bought off ebay so i will have to check and see what the rpm's are while ridding. what is the redline on these bikes? |
#17 |
If you ride mostly on the street, the 14T countershaft sprocket will work well for you, Alan. When you replace the counteshaft sprocket, you will need to remove the entire left crankcase cover. Therefore, you would be wise to perform the left crankcase cover modification at the same time.
![]() http://chinariders.net/modules.php?n...ewtopic&t=7559 The redline for the Zongshen 167FML engine should be the same as the redline for the Yamaha, TW200 engine, around 9,500 rpm. ![]() Spud ![]()
#18 | |
#19 | ||
![]() ![]() Spud ![]()
#20 |
I think all of Spud's suggestions will get you going right. Maybe the zong would prefer some white lightning in the tank. :wink: We are in the right area.
Allen
#21 |
I think that these little engines run out of breath before they run out of revs.
Spud, maybe your next mod could be a tachometer? :idea:
Happy to serve. |
#22 | |
#23 |
I just wish Q's had a tripmeter, or a gas gauge. :(
Happy to serve. |
#24 | |
#25 | ||
What's the status on the drive gear replacement?
Happy to serve. |
#26 | |||
#27 |
How much for the speedo drive?
Happy to serve. |
#28 | |
#29 |
Copy that. AT least the parts are very easy to get, just a click away. No worries or searching.
I'd have done the same thing as you. I'd be inclined to send the Q people the broken part and see if maybe they'll do good by you.
Happy to serve. |
#30 | |
