09-09-2008, 07:56 AM | #1 | |||
09-09-2008, 09:12 AM | #2 |
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
09-10-2008, 05:34 AM | #3 |
2006 LF 299G-Y:
Spot welds breaking. Rubber component mounts breaking and cracking. turn signal broke from "garage rash". fuel line made of vacuum hose. :roll: lost rear disc mounting screw. clutch switch broken upon delivery. Several headlamp bulbs. Plastic instrument lenses hazing. loose fasteners galore. And for what it is worth, the electrical diagram must have been developed in kindergarten!
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
09-10-2008, 11:39 AM | #4 |
-Broke one exhaust stud.
-Broke the longest engine mount bolt. -Tab for the headlight adjustment screw broke off. -Chain slider quickly wore out. -Shaft for rear monoshock came unscrewed from its upper mount. -Housing on left handlebar for light switches cracked (could have been from drop). -Right mirror broke off--cheap plastic. -Broke right side cover--cheap plastic. 1600 miles on bike.
2006 Lifan LF200GY-5 |
09-10-2008, 05:24 PM | #5 |
I have to add my rear brake system is a bummer, the pistons often jam and cause leaks that splatter the right side of the rear tire, very messy to clean and bleed out old fluid......I will need to get a piston tool to get those out to clean around as I had fixed this about a month ago and it started again....Ive since removed the caliper cleaned everything and shoved the pistons back as well as bled the system again phew!
09-10-2008, 05:29 PM | #6 |
Forgot a few things. Clutch switch broke. Clutch diode broke. Most of the rubber mounting things are gone.
I have had to fix some of the wiring with new connectors and also rebolt my engine. Original tires replaced after worn out. Almost ready for my 3rd rear tire. I will say that I don't perform the best maintenance on my bike and it has NEVER (18 months) been washed. Ridden in the mud, rain, sand, water crossings, been laid down a few times. I do check for loose bolts, lube the chain, check the tires and lights, and change the oil regularly. Also I followed the DS prep guide thoroughly before riding my bike. I think that proper setup is the BIGGEST factor in getting the most from your bike. This is what a good dealer should be doing and is why alot of these bikes that were bought online or from a roadside vendor have alot of the problems that they do. Allen
09-10-2008, 06:12 PM | #7 |
Biggest issue I ever had was the rubber mounts on the coil rotted into powder and other misc rubber on the bike. Also the front rim was never quite true and the spokes always came loose. But I only had my bike for about five months before I sold it so More might have happened later on if I had kept it. All in all pretty good lil bike.
09-10-2008, 07:21 PM | #8 |
2007 shineray 200xyi DS
Just had the clutch cable brake on the way to work this morning. But i think i set it too tight :oops:
John 2007 Shineray200XYI 2007 Vento Vthunder 250 |
09-11-2008, 04:59 AM | #9 | |
It may be salvageable :wink: Tigertamer
09-11-2008, 04:55 PM | #10 |
Oh yeah Super cheap mirrors on my GY...bothered me for months, left is OK but right would rattle with every bump or gear change, finally driving down the highway trying to adjust it snap and the rest is history, $20.00 replacement today much better placement and quality!
09-11-2008, 09:39 PM | #11 |
Rear master cylinder died too.
Replace with honda part. Works great. Allen
03-27-2009, 03:16 PM | #12 |
Flat spotted tire (replaced with Dunlop)
Top Fork bolt came off (Retorqued) Fuel line rupture (Replaced) Petcock broke (Bypassed) Battery bracket broke (Relocated,Replaced with lawnmower battery) Turn signal,Taillight bulbs shorted and burned out (Bulbs unavailable-Rewired using 1997 Yukon tailight circuit boards) Front parking light bulb shorted/blew (Repaired socket,Replace w/ LED) Brake lights inop (adjusted switch) Power wire caught on fire (replaced with 2g) Voltage regulator caught on fire (Replaced) No Fused circuits (Installed distribution block) Rear end shimmy (Replaced coilovers with YZ80 units) Rear end clunk (Replaced Hanger bolts) Intake manifold fell apart after installing N20 jet (Replaced) Valves ticking (Port/Polish/Adjust) Weak spark (Replace plug,unshrouded electrode) Door latch loose (fiberglass reinforced) Door latch inop (Broken/Repaired-broken parts/spring in door) Outer door handle inop (Repaired-misadjusted and broken lever) Inner door handle inop (Repaired-fiberglass reinforced,rod repaired) Stereo inop (Replace-Pioneer DEH6500) Speakers blown (Replace-Pioneer 6x9's) Wiper blade missing/unavailable (adapted DL11" blade) Carb gunked (rebuilt carb) Low Power (installed 2-5hp adjustable Nitrous) No fuel pressure for Nitrous (Installed standalone fuel system) Rear end funky (replaced fluid) Things that need fixing. -New carb -Seats need recovered -Sunroof needs repaired -Speedo cable need repaired -Need new/quieter exhaust -New Air Filter *Burnt lo beam bulb (Unavailable-Grafting 1997 GMC Headlight socket in process) I know i've fixed alot more than that,and alot more needs done. But it's a start. |
03-27-2009, 07:22 PM | #13 |
Front tyre bulge and no grip - new tyre
Front brake squeaky and just rubbbish - working on mounting a 4 pot Headlight bulb Pretty much all of the wiring around the headstock - re-wire Footpeg bent - not for jumping these bikes Rear rack - dont try and carry car wheels about Rear indicators Brake light Chain and sprockets Shock/Damper Rear "ABS" - nothing... nothing...nothing... oh and now im sideways Battey Box and connectors - Wheel Bearings Idiot lights Platsics Rattled Cush drive - no likey the one wheel riding ... all i can think of at the moment |
03-28-2009, 02:19 AM | #14 |
I am very pleased to report that after 9,500 miles I have not had any mechanical problems with my 2006 Zongshen Sierra 200GY-2.
However, I have replaced several consumable items: After 4,000 miles, replaced worn-out original drive chain with Tsubaki 428HQR drive chain Replaced two burnt out light bulbs illuminating the speedometer Replaced burnt out 35W/35W headlamp with 45W/45W headlamp Spud
03-28-2009, 04:28 AM | #15 |
On my GY6, nothing so far.
