Old 11-22-2023, 05:53 PM   #16
BriNbigD   BriNbigD is offline
BriNbigD's Avatar
Spacers used
Thanks Megadan for sizing!
https://www.amazon.com/dp/B09DK5PPRW...t_details&th=1
https://www.amazon.com/dp/B09DK8LRXZ...t_details&th=1
Fit perfectly. Still was a total PITA to get them in there!
ID:	30442   Click image for larger version
ID:	30446   Click image for larger version
ID:	30447   Click image for larger version
ID:	30448   Click image for larger version
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 EX400G Ninja 400
2023 Hawk DLX
Old 11-22-2023, 06:03 PM   #17
BriNbigD's Avatar
Pod and filter
Did the air box delete and added the pod filter and crankcase breather filter. I did notice I had a loss of power and top end after this install.
https://www.amazon.com/dp/B0881KNMCM...roduct_details
https://www.amazon.com/dp/B0146I3H42...roduct_details
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-26-2023, 01:22 PM   #18
BriNbigD's Avatar
Rear sprocket
I’m having trouble sourcing a JT 42 rear sprocket on the new DLX. They’re all 6 bolt patterns. The 43T seems to not fit:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Any ideas why this one wouldn’t fit?
Thanks!
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-26-2023, 08:35 PM   #19
BriNbigD's Avatar
Review
I would think so to, but there is a specific review saying it won’t fit the new DLX…
I’ve bought other parts that haven’t fit. Will be glad when these bikes get even better aftermarket support.
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-27-2023, 07:46 PM   #20
Jax11's   Jax11's is offline
Bought so a 23 DLX and read about all the stuff I needed to do! . Rec bike and was astounded at all the improvements that were made after 2018 list on this website.
looked like they were directly looking at what you all talked about!
JW
Old 12-15-2023, 10:13 AM   #21
BriNbigD's Avatar
Replaced rear brake line with: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Fantastic results. Brake is very firm and immediately responsive. However, the brake switch has already failed! So today I’m installing: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Will report results and some pics after I’m finished.
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 12-15-2023, 03:06 PM   #22
Do©Hawk   Do©Hawk is offline
I still have the rubber brake lines, but I changed out the brake light switch early on and never looked back. It's a great cheap improvement and it's worth changing even if the crappy plastic one isn't broke. Take a hammer and bend the old mounting tab against the frame. You could grind it off too, but I didn't want to eliminate that mounting point.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* LED headlight + front turn signals
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 12-15-2023, 06:19 PM   #23
buzz   buzz is offline
Mine all stock brakes and no problems,changed pads once in 8000 miles.17 front and i think 37 on back wheel,70 mph top speed. Think it might go a little faster,will find out in the morning.2021 TBR7 that i thought the transmission was going bad,but just a junk chain i installed around 3000 miles. Never saw a chain so kinked up,it was cheap my fault.
2023, rps hawk
