#16 |
And the ZS172FMM engines are nice. It has the OHC head. I have the 5 speed, used to own the 6 speed (counterblanced). You can buy it with a complete motorcycle with adjustable suspension for under $2000 (Templar). I agree, just buy the bike. THEN tinker!
#17 | ||
This is about you moving the goal posts when an argument is defeated. Perspective and preference has nothing to do with my points being factual and completely valid. This is a case of a $500 motocult kit is the cheapest way to get the power they are after. It's cheaper than swapping the engine to something that gains them nothing more than an OHC engine with less power than the motocult kit would provide them on their CG engine. Cheaper aside, it's also WAY less work to simply install the motocult package than it would be to swap the engine. All the same arguments that I made previously, all of them still entirely relevant and true. I don't know, maybe I missed where the OP asked about Swapping in an engine? Here is the first post for a refresher. Quote:
Anyway, argue amongst yourselves at this point. I'm beyond this silliness.
#18 | |||
38 ish hp, parallel twin smoothness, 6 gears, 14,000rpm redline, Kawasaki reliability... |
#19 |
...and snap a frame weld...
2023 Hawk 250 from XPRO off of Amazon MOUNTAIN MAN RC + MOTO on YouTube "If there were more bloody noses, there would be less wars." - Hagbard Celine "Someday, after mastering the waves, the winds, the tides and gravity, we shall harness for God the energies of love and then, for the second time in the history of the world, man will have discovered fire." - Pierre Teilhard de Chardin |
#20 |
Then you repair and re-weld it.
Or... or... just hear me out here... Since you'd have the entire thing basically stripped to a bare frame anyhow, how about going through each of the frame weld points and inspecting them, rewelding as needed, and adding bracing where identified weak points exist. Just because you have 40hp in a bike frame doesn't mean all 40 horsies are being applied at any given time either. Hell, even on a stock bike, unless you're going WOT up to 8000rpm on every ride, you're not even using all 15-16hp there either. Anyone capable of stuffing an EX250f engine into a cheap XR clone frame is certainly capable of reinforcing and ensuring the frame is able to handle it. |
#21 |
I honestly wouldn't worry about the frame.
The swing arm and it's mount point are, in my opinion, the weakest part of the Hawk.
#22 |
The last 2 bikes, that I have bought have both been used, but each with almost no miles CG type Chinese Dual Sports, and I paid $1,900 total for both. $1,300 for a titled 2021, TBR7D ( was just a few months old at the time, showings 425 on the odometer,and had 42/17 sprockets, and rejetted carb), and $600 for a 2016 Hawk, that I bought last December, and it was showing around 100 on the odometer, if I remember right, it had sat in a storage container for years, and had only been used on the people's property, but it already had a VM26, and folding shifter on it. The front tire was pretty much flat, but it's not given me any trouble since I pumped it up. I put fresh gas in it, after getting home with it, and it wasn't too hard to kick start, but the clutch would not release. I got the clutch releasing within minutes by pulling the lever, with the bike in gear giving the bike hard sharp pushes forward, almost like rocking a car back, and forth to get it going in the snow. I have rode the bike enough to confidently say that my clutch is fine. That being said, I don't think I would buy another CG type new, because of some of the newer bikes having the 6 speed, OHC , BUT, I can honestly say that buying a used CG bike, and then going with the MotoCult total package, could make sense, especially, if you're content to stick with the CG bikes. I don't know if the Chinese OHC bikes are more dependable, and I honestly don't need a 6th gear in mine. I recently ported my head, and advanced ignition timing 4 degree, and instead a CSC head gasket on my TBR7, and picked up some more power, and that's probably about all the Nibbi PE28 can flow. I waited so long to do it, because I was already satisfied with the bike with just exhaust, and pod filter. I will probably port, and polish the Hawk head, and even though I only ordered 1 head gasket from CSC, I got 2, but I really enjoy my Hawk, now, with just cat , and baffle delete, and pod filter.
#23 |
I absolutely agree. If I were buying a bike today, I would get a Templar with the 6 speed trans or spend the extra for the.KPX 250. Hands down, not a single argument from me.
That said. A stage 3 motocult equipped CG250 makes more power to the rear tire than the 172 engine makes at the crank.
#24 |
Spot on Dan. I've watched with anticipation the Zongshen 172FMM 6 speed engine install on our Hawk250 Facebook page. Frankly, I'm not impressed. From what I've read, stock with the 172 is 19HP at the crank. With upgrades, as you've noted and has been proven by MotoCult, we can at least get our CG250s up to 20HP at the rear wheel. Thus, the conversion just isn't worth it to me...but that's me. I'd rather just buy a Templar X outright.
#25 | |
#26 |
Is there any difference in the quality, or strength of the bottom end of the Chinese 229cc CG motors, and the OHC motors that a lot of the newer Chinese bikes are using?
#27 | |
The main limiting factor for the cg goes back to it being a pushrod engine woth a single lobe cam. It will never rev as high as an OHC engine, but it makes up for it with better low rpm power.
#28 |
I bought the MotCult head/base gasket set. I can not find any videos on these specific gaskets and whether or not you need to use the oil seal o-ring? I did find a video on the CSC head gasket for the TT250. He gives a shout out to MegaDan for the advice to not use the o-ring. Wondering if the same applies to the MotoCult gasket?
#29 | |
For what it's worth, my 2024 CSC TT250 didn't have an o-ring, nor did one go in when I installed the Motocult stage 3 kit and gaskets. No leaks here and I'm a happy camper with the performance, particularly after enlarging the stock exhaust tailpipe and adding a Nibbi PE28FL.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come. |
#30 |
How many miles since you did the stage 3? Can you hit 70 mph with ease, now? Also, very interested in that "custom-made cable controlled choke". How you do that?
