Old 01-03-2023, 07:13 PM   #16
WindMindMusic   WindMindMusic is offline
WindMindMusic's Avatar
Now that you are in a deep freezer, the M will remain parked for a couple of months
So you can do the carb work.
I have the same engine- ZS172FFM-3A
I recommend increasing from #40 to #42 pilot and #120 to #125 main jet.
I had a #45 pilot in there, but too rich. You can shim the needle about 1mm.
I can send links to posts where these instructions with photos are. The are in the pics and video section in Temp X (2022 1/2) thread, page 2..
Stay warm!
Thanks and here is the video I made re: 16T Front sprocket, showing clearance.
First road ride X-Pro Templar 250M https://youtu.be/k3kA_JZEGyk
Windscreen: EGO BIKE Smoke 18*16 Tinted... https://www.amazon.com/dp/B019Z6VA4Y...p_mob_ap_share
16T 520 front sprocket: WPHMOTO 520 20mm 16T Chain Front... https://www.amazon.com/dp/B0865YF176...p_mob_ap_share
Simple, cheap exhaust wrap: Titanium Exhaust Wrap 1" x 16'... https://www.amazon.com/dp/B073ZBF72X...p_mob_ap_share
Old 01-03-2023, 07:19 PM   #17
Old 01-03-2023, 09:46 PM   #18
Originally Posted by WindMindMusic View Post
Still riding. Battery took a dump. Leaking acid. I guess they cut corners there to give a better overall product. Looked up the battery on Ali and it was $6 Lol going to upgrade it.
I got a good 80 CCA battery for about that just fits into the battery cradle. Weize YTX5L-BS
But might not be available now, but Mighty Max brand is, and others for about 20 bucks with the same part number. Check dimensions if possible, but looks good. Returns are OK.
aftermarket, carb, modification, power, templar
