07-03-2022, 09:25 AM | #16 |
No check engine light? Air filter clogged, fuel line kinked, vacuum in the gas tank, brakes dragging?
07-03-2022, 03:44 PM | #17 |
Oxygen sensor
I believe I found my problem, but not the part to fix it. O2 sensor code comes up, reads open with an ohm meter, where can I get a replacement?
07-03-2022, 06:22 PM | #18 |
Any numbers on it? Does X-Pro have parts? 2 wire or 4 wire?
07-05-2022, 01:07 PM | #19 |
Running again
You are not going to believe this, I checked o2 sensor again hot and it was working correctly, so I went back to troubleshooting, I read on the internet to disconnect the battery and reconnect. Sounds really stupid, but I was desperate and it would only take a couple minutes to try it. THAT FIXED IT, the ECU lost it's mind and needed rebooted, who knew?
07-05-2022, 07:00 PM | #21 |
Or Windows CE...makes ya wanna WINCE!
Nuff said. olds_cool63 ======= Johnny Pag Pagsta (replaced 50cc engine with 110cc, modded-out) 2007 Tank Vision Topline Khaos (cosmetic mods, cherry-bombs) 2005 Kymco Vitality 50 2T (70cc big bore kit, other race mods...tops out at 67mph) 2008 Hyosung GT250 (cosmetic mods) 2001 Suzuki Bandit GFS1200S (cosmetic and slight mods...150mph+) |
07-05-2022, 08:01 PM | #22 |
08-02-2022, 09:42 AM | #23 |
Finally got around to checking the odometer this morning. It's off, just like the speedometer. To calculate the actual mileage multiply mileage shown by 0.825. 1 mile shown is 0.825 actual.
Also I've noticed it's easy to scrape the center stand on left hand corners. The tires grip well on dry pavement |
11-28-2022, 03:05 PM | #24 |
Belt
I recently purchased Vitacci Force which is similar to Vitacci Clash but it is not running smoothly and making lot of noise, I feel the belt of the scooter is not good and needs to be replaced, Can anyone recommend a high quality belt for this scooter? I see online they are selling belts for 50cc and 150cc scooters only and nowhere I can find 168cc.
