#16 | |
I'm a sex therapist. I get to deal with enough drama and don't need any more!!! ![]() Knew about the cooking oil it comes with but the .006 and .008 I thought was something to see if it needs rather than taking all the stuff off and doing it from the get-go. Any reason it would harm the bike to wait on it? Thanks |
#17 | |
Ok, that's not bad. If you had come back and said to be prepared for $500 I'd be holding off on the purchase. Thanks! |
#18 | |
BTW if you run out and have to put it on reserve, you can stop, lean the bike to the left, meaning almost onto the ground, to get gas from the right side over to the left where the petcock is. The half gallon or whatever trapped on the right side is useless over there. Some bikes have a balance tube under the tank to get the right-side gas over to the left. Mainly older bikes I think, and pre-fuel gauge.
#19 | |
![]() 2. I would check it. You have to remove the two completely useless plastic tank thingys and the rear gas tank bolt, then prop the rear of the tank up with something. I use a small piece of 2x4. I leave the tank thingys off, since I hate them.
#20 |
As noted by Tom, to do the valves all you have to do is remove a couple pieces of plastic, remove a bolt at the back of the tank and stick a piece of wood under the back of the tank to lift it up a couple inches. That gives you enough clearance to remove the valve cover.
My valves had basically no clearance when I checked them after around 100 miles. Maybe they were fine initially. The valves often tighten as things wear, so they may have tightened during break in. After adjusting them it ran slightly better. |
#21 | |
#22 | |
Felt all smart telling them what they needed to fix on their bike and it was already done. Ha ha Tires: rather than looking through all the options which was giving me a headache, and considering the stock tires worked great for 5000 miles, I just bought the stock tires again. $85 each. Valves: It seems some places actually do adjust them before you get them. I haven’t opened mine to look at them yet. 5000 miles. But they are due. They are overdue.
2020 Lifan x-pect |
#23 |
No, that's just to get every last drop out of the tank. Unless you are out in the boonies, just switching to reserve should get you to a gas station no problem.
#24 | |
Huh. Your comment made me look at my 2021 model and there is plastic conduit on the wiring harness near the head tube. It's wrapped in electrical tape, so when I looked at the wiring before I didn't notice it. |
#25 | |
Oh ok got it. Appreciate the clarification. |
#26 |
How easy is it to change out the halogen and switch over to an LED for a headlight on the X Pect? What all is involved in the procedure?
Thanks! |
#27 | |
Yep. That’s the part that was missing on mine. They just had bare wires kind of taped together half assed with one maybe two layers of electrical tape. It wore through very quickly. When I went to go to show somebody I know how to fix that on their 2021, it was already done. Which really surprised me.
2020 Lifan x-pect |
#28 | |
Thanks |
#29 | |
The turn signals and rear taillights are LED, but the headlight is not. Not sure if this is the same guy, but he recommends just swapping the headlight for a better halogen, not LED. But the procedure is the same: |
#30 | |
Yup that was him. I must have clicked off before seeing the install. Thanks |
