Old 09-22-2021, 10:39 AM   #16
Marc Hufnagel   Marc Hufnagel is offline
Originally Posted by China Rider 27 View Post
Here is a link on clutch adjustment. After you have it set up, see if you can use the adjuster at the lever to take out the slack and see if it will improve the clutch release.
https://cscmotorcycles.com/tt250-clu...on-adjustment/
THe one thing it doesn't really say is how far forward should the adjustment make the engine case lever? Just to the point of resistance met or further or some slack at the arm?
Old 09-22-2021, 10:47 AM   #17
franque   franque is offline
No slack at the engine case, it will be under slight tension when adjusted properly. The lever there is taking up some spring tension inside, so there should be no free play there. The only free play should be in the lever on the handlebar.
Old 09-22-2021, 10:48 AM   #18
ok that helps, thank you I'll check this again this afternoon. Engine cold or hot?
