Old 08-02-2021, 04:24 PM   #16
Lukas   Lukas is offline
Dear charles, currently my bike is 249cc and the map is for 249cc, only when I buy a 299cc cylinder, it is possible that such a map will be created, I can make a video from A to Z, how to download the bin. ECU and how to upload TO your own ECU file, which you then send to oldschool tuning, you can write that you want one like mine and they will send it to you. When I change the cylinder, maybe I will be able to make a map for 299cc, in fact this is my goal, but there are still some problems, but it is possible that I will be able to solve them Now the bike runs really well, I can go to 5th gear, at 4000 RPM it accelerates nicely, before to 6200 RPM nothing was terribly mulled I also have the second map more powerful, but the bike does not run as it should, because you can not add parameters endlessly, but it may be ok on a larger cylinder.
Old 08-02-2021, 10:22 PM   #17
Chris_Top_Her   Chris_Top_Her is offline
Chris_Top_Her's Avatar
Originally Posted by Lukas View Post
I need help I want to change the injection map on my rx3 I need to download a bin file. Which i want to send to https://oldskulltuning.com/ they will modify the file they will send me and i will have to upload it it involves a big plan because i want to put big bore kit 84 unfortunately when i try to download the file using elm 327 USB interface V1.5 in HUD ECU HACKER v3.7 i get an error,Is there a step by step procedure on how to do this in hud ecu hacker generally the interface connects and shows parameters, but when trying to download the file an error pops up. can anyone help me.
Luke, would you mind linking where you got your Chinese open port? I have a genuine Taxtrix from tuning my Car, but other riders will not want or need to pay genuine pricing for these bike. Thanks.
CSC RX4 2020
Old 08-03-2021, 08:15 AM   #18
Chris_Top_Her
https://www.aliexpress.com/item/1005002060918189.html?spm=2114.13010708.0.0.10e85c 0fWFQD8E
Old 08-03-2021, 08:21 AM   #19
Two big borers I don't know which one to choose?
https://www.aliexpress.com/item/4000440337370.html
https://www.aliexpress.com/item/32905057953.html
Old 08-03-2021, 08:37 AM   #20
Falkon45   Falkon45 is offline
Falkon45's Avatar
The link to the open port doesn't work.
Old 08-03-2021, 09:24 AM   #21
Working_ZS   Working_ZS is offline
The link opened for me, in Vivaldi, which even translated the Polish into English automatically. Here's another link to the exact same page, but in English:
https://www.aliexpress.com/item/1005...fcd7c944440-47
Edit: Just checked it in Firefox and Opera; both opened it just fine. Opera even wanted to install the AliExpress shopping extension, which I declined.
Old 08-03-2021, 09:36 AM   #22
HUD ECU HACKER 3.8 is redy, thanks sir Elmue
Old 08-03-2021, 09:45 AM   #23
They appear to be from the same seller: if you scroll down a bit they both appear to be coming from the "2088 Official Store". I would get whichever is cheapest at the time that you place your order. Right now, that's the first one; it's listed at US $208.78 with free delivery.
Old 08-03-2021, 09:55 AM   #24
HUD ECU Hacker 3.8
Here's a link to the HUD ECU Hacker web page:
https://netcult.ch/elmue/HUD%20ECU%20Hacker/
The button to download the program is almost at the bottom of the page ; there is a ton of connector pin out and recommended connection type information, in addition to some information on the Delphi MT-05 ECU itself. Quite helpful for anyone looking to alter the EFI mapping on their Chinese motorcycle, to say the least.
Old 08-03-2021, 10:50 AM   #25
I know the seller write is of the same quality, but the cheaper one has no comments from the buyers and the more expensive is checked
Old 08-03-2021, 11:07 AM   #26
Falkon45's Avatar
Odd. Link does not work for me with chrome or microsoft edge on my work computer. But it works on my phone. Hmm. Unusual, because I can go directly to aliexpress on my work computer.
Old 08-03-2021, 06:36 PM   #27
I buy expensive one.
Old 08-03-2021, 07:46 PM   #28
Good luck on the big block upgrade, keep us posted on your progress.
Also, be sure to check the piston skirt to crankshaft clearance on your kit before you seal everything up and start the engine for the first time. Choppercharles received a bad kit on his build and ended up going back to stock; hopefully yours ends up better than his did. Then you can tune the EFI to take advantage of the increased displacement, put it on a dyno, and let us all know just how powerful the RX3 can really be!
Old 08-24-2021, 06:21 AM   #29
finally
Old 08-24-2021, 10:37 AM   #30
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
It wasn't the skirt contacting on my big bore kit, it was actually the wrist pin bosses were not machined down. Skirt cleared the crank, but not the wrist pin bosses. You can see the contact marks in the pic below:
Charles.
