#17 |
So since the housing isn't really broken, just a little loose, i think i will just wrap it in electrical tape. BUT, for the short tube, i ordered this.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#18 | |
Gotcha - you may also be able to use some shorter bolts. Without seeing, I can just picture the bolts bottoming out before it gets to snug up with the bar. My only issue with the tape, is that it may slide around with the adhesive - I would use a thin strip of rubber; old tire inner-tubes would be great. Just my thoughts though - I'm sure others would suggest better lol Do you have or plan to use brush guards later? That aluminum throttle looks good! But, most of the guards go through the handlebar tube and pressure lock to the inside of the tubing.. Last minute thought!
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
