11-21-2020, 03:09 PM | #16 |
Canada?? Shoo - I'll tag along; those are the most amazing views while riding. I'm jealous lol
Yep - all those links are the same one that I got, 30mm Mikuni style carburetor. Filter may be a little different between them all, and I even got an extra spark plug; doesn't fit.. so just in the scrap pile of things I need to do something with. My new carb also came with a new spacer with o-ring seals to go between the carb and the intake plenum - as well as a new (also didn't fit) intake plenum. My stock spacer had a gasket on it that was destroyed when I removed the stock PZ30 carb. so the o-ring one was handy. Though, it is smaller in diameter compared to the stock one, inside diameter. Not sure if that makes any difference on anything, but so far - this was much better than the stock one. No issues idling or accelerating / decelerating. I kept the stock air box - just works better compared to the stupid pod filter. +1 KenTaoyan: I couldn't do anything until setting valve lash - this should be (I'm sure it is somewhere) like the FIRST thing people need to know before doing anything else after receiving them. I'm kind of disappointed that the bike came "ready to ride" and the valves with 0 gap. But also didn't pay the other 10K to get a dual-sport. Be safe on your adventures, man!
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
11-23-2020, 10:46 AM | #17 |
The first time (learning experience) on replacing a carb on my Honda XL185s I put the cylinder/needle in wrong thus giving it about 85% throttle when started. The cylinder goes in two ways, one being a little deeper.
maybe I just got lucky but after not running it for a week, I flipped up the choke it started right up, gave a little RPM and flipped down the choke and it purred like a kitten. I'm not sure on the TBR7 as I have the 2020 Hawk but adjusting the lifters (Valve lash) made a big difference.
~ toys in the cave (in the order of addition) 81 Honda XL185s {work in progress} 2018 QIYI Coolster 3150CXC 150cc Quad 2019 QIYI Coolster 125cc Quad 2021 Roughhouse 50 (neat little scooter for the wife) 2022 QIYI Coolster 3150DX-4 I may not be fast but I am "Half-Fast" |
11-23-2020, 10:55 AM | #18 | |
http://www.chinariders.net/showthread.php?t=27511
11-23-2020, 10:59 AM | #19 | |
11-25-2020, 07:17 PM | #20 |
https://www.amazon.com/Carburetor-Un...6345697&sr=8-4
Anyone use this one?? I had to get an adapter with it - haven't received yet. Looked a little cool.. Others that have used it have said it's better than the VMXX's .. has a negative pressure tube? Just wondering - I'm going to try it out and see if it is any better. Comes with a 120 main jet though.. might start with my 110 - given that it fits; mine are for 'Mikuni' style carbs. We shall see.. Not your standard 2 bolt hookup either.. have to get a rubber adapter to use this one. Kind of like the 'cold air' intake hookups. I'll give some reports on what I can tell between my VM26 knockoff and this one. Thank goodness the mix screw is on the side rather the bottom I almost scraped off my threads trying to get my mix set one time lol..
