Old 09-22-2020, 02:29 PM   #16
RK97   RK97 is offline
I may take some video or time-lapse pics. No one needs another unboxing video, but i will try to put together some first ride stuff, and definitely get track footage if i take it to the kart track.
Old 09-22-2020, 06:45 PM   #17
It’s here. Changed the oil, added gas, and it started right up.
...but i am getting a clicking noise from inside the engine while
coasting.
Removed the front sprocket cover. Not a loose sprocket. Need to investigate further, but I’m worried it’s internal and not going to be simple to diagnose or fix.
Old 09-22-2020, 06:50 PM   #18
Upon further investigation, the “tick” only occurs rolling forward, not rolling backward.
Old 09-22-2020, 08:52 PM   #19
And the clutch cable has zero free play adjusted as loose as possible. Hoping it stretches.
Old 09-22-2020, 09:20 PM   #20
Thinking the “tick” has to be a chain issue (likely too tight), because it occurs with the bike off, and in neutral - so nothing internal should be rotating. Going to slacken up the chain and see if that helps.
But i hear it every revolution of the sprocket. That worries me. If the countershaft is bent... ��
Old 09-23-2020, 02:34 PM   #21
Confirmed VIN for MCO at lunch. Chain is BANJO tight ��. Will remedy that and check oil level after work. Chinese assembly ����♂️
Old 09-29-2020, 05:52 PM   #22
MCO arrived in the mail with Bill of sale today!
Gotta skip some work tomorrow to get this thing plates ��
Old 10-02-2020, 06:06 PM   #23
Bike was stalling after it got warm. Unhooked evaporation canister, and running fine.
But now leaking oil. From ...not the drain plug.
Old 10-06-2020, 05:00 PM   #24
kirbo7106's Avatar
If I were looking for a Grom Like Vehicle, I would look hard at Venom Motorsports. Most of these Chinese motorcycle dealers are hit or miss. Venom seems to really have follow up after the sale. I’ve had some bad experiences with 3 different dealers.
Keep us posted on what you decide to get.
Enjoy the Ride!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 10-07-2020, 10:49 AM   #25
I think i solved it. Videos with explanations. Although i didn’t take much video with the fairings off...
And
Old 10-07-2020, 10:52 AM   #26
GPS top speed says 45mph ��
Granted, i was in a 35 zone. I will take it to the Redbox, which has a 45 zone over the valley, and provides a safe place to push 60. It used to be a 55 zone, and i would do 0-60 acceleration pulls in my 1993 Probe GT in high school. I was a rebel ��
Old 10-08-2020, 08:07 PM   #27
Over 60 miles now. GPS top speed with a passenger, and a slight downhill is 49.
But it’s not leaking or stalling. Guess it’s time to order a pipe and a carburetor.
