#16 |
I thought disconnecting the battery and leaving it in the cold shed over the winter was ideal ?
That is my current scenario with my TBR7 ..Its winterized and lifted on a cinder block and the battery is sitting on a shelf ( no tender in sight ) |
#17 |
a good name brand tender is the best, as it will keep the cells from freezing even in extreme cold, as well as keep the battery charged and maintained. second best is removing the battery and storing it somewhere cool and dry, and not sitting on concrete. the concrete can leach the water out of the battery and cause it to go bad, just like leaving a plastic gas can on concrete can absorb moisture into the ethanol. if you store a battery in a garage or shed with no tender, i recommend placing it on a piece of wood at the very least. this will insulate it from the concrete (same goes for your gas cans.)
#19 |
#20 | |
#21 |
I have seen a concrete floor drain a lead acid battery over time as well however I all ways believed it to be a capacitave effect between the floor and the electrolytes and plates. Not from water molicules migrating through the plastic.
Good judgment comes from experience, and often experience comes from bad judgment. MY BIKE'S THREAD |
#22 |
#23 |
What Interstate Battery has to say about it:
“The type of plastic (polypropylene) used in battery cases is a great electrical insulator. Also, tremendous technological improvements have been made in the seals around the battery posts and vent systems, which have virtually eliminated electrolyte seepage and migration. So, it’s OK to set or store your battery on concrete.” |
#24 |
Myth unless your dealing with a battery that belongs in a museum. Any lead acid battery will go dead over time, all batteries slowly self discharge. If the battery has a cell with higher IR it will drain much faster, even when the battery seems to work fine. Pb batteries are better than nicad or nihm batteries but no where as good as Lithium when I come to self discharge. I still wouldn't store the battery directly on the floor just incase it leaks.
