Old 01-09-2020, 08:01 PM   #16
Mudflap   Mudflap is offline
Pretty much all the fasteners on the Rhino are flange bolts and nylock nuts so no loctite needed. Never had a fastener come loose on mine in 700 hours.
Old 01-11-2020, 11:48 PM   #17
Originally Posted by Darth Racer View Post
Ok so not too bad... it's on it's way... cool.
Brush up on some of the threads here that talk about putting it together... the fender flares can be tricky... I have a thread on it http://www.chinariders.net/showthread.php?p=215343. Throw the wrenches out that come with it.. they are useless.
Get a small bottle of BLUE Loctite
Drain the stir fry oil out of the crankcase and replace with 15/40 Rotella oil. Get a couple of quarts. It's good to change out the oil after the first break in run (4hrs of riding or so) Clean off the bits of metal from the magnet on the drain plug
Pick up a couple of NGK spark plugs.. it will start easier
Clean out an area of the garage to do the assembly in
It's winter now... don't leave that battery out in the cold or it wont last long at all.
Just another thing to add to the great advice from Darth, set your valve clearances. Most of these CB's come from the factory with tight valves.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 01-14-2020, 05:47 PM   #18
justin1328   justin1328 is offline
justin1328's Avatar
Received.
Thanks to everyone for the warm welcomes and advice. Received my Rhino Friday afternoon 1/10/20. First thing I did before assembly was to sand, prime and paint the entire body. Wasn’t a fan of the blue. Went with a dark charcoal metallic enamel and it turned out great! Changed the oil and used Royal Purple break in oil. New NGK Plug, 2” rear spacers, and aligned the front wheels. One odd thing I noticed was that when I changed the oil, there was shavings on the drain plug and the oil was a little dark. Assuming they test run the engines before mounting??? Getting ready to add a front and rear light bar, Trail Tech Vapor and a couple odds and ends. Anyway, I will post pictures once I figure out a hosting site for the pics. Thanks again to everyone, looking forward to contributing in the near future. Praying for a BIG snow storm in the coming weeks 😊
Old 01-15-2020, 09:07 PM   #19
Darth Racer's Avatar
Shavings are normal from what I understand on new small engines.... its why you do the first handful of oil changes after only a little bit of riding.
Yes I would imagine they do a test to make sure it runs before shipping... avoids a lot of BS on returns.
If Mudflap says Loctite not needed then you should be good.. I do vaguely remember some of the bolts were nylocks ... some weren't think the fender screws are what I put it on mostly.
Yes please do post some pics.. Charcoal sounds sharp with black trim... Imgur.com works pretty good for images.
Old 01-16-2020, 12:39 PM   #20
justin1328's Avatar
https://imgur.com/gallery/SkY78kP
Old 01-16-2020, 10:10 PM   #21
The link doesn't work Justin.... copy paste the "direct link" to the image.
Old 01-24-2020, 12:24 PM   #22
She came out looking real nice.
2004 Honda ST 1300
Old 01-24-2020, 02:20 PM   #23
justin1328's Avatar
Jerry, Thank you, and I am grateful for this community for being such an amazing resource. Gave me the confidence to pull the trigger on the purchase.
250, break in, oil, rhino
