12-27-2019, 09:55 AM | #16 |
the sidecar will be no where near as complicated as the suspension and other things you did. it's really quite simple. AFAIK the angle of the hub is 0 degrees. when you connect the sidecar to the bike, you should have it angled in about 7/8 inch over a 6 foot length. I used a laser aligned along a 2x4 which was put against the rear wheel. I made marks on the garage floor in front of and behind the bike. when I attached the sidecar, I did similar markings based on the sidecar wheel. you want the front mark distance to be slightly less than the rear. in essence, toe in.
when you set up the sidecar to the bike, have the hub of the sidecar ahead of the hub of the rear wheel. on a shorter bike like the 250, perhaps start with 5 inches ahead. you can always adjust based on how it feels. the thing to remember with sidecars is it's as much an art as it is a science. tinker until it feels right to you. |
12-27-2019, 10:00 AM | #17 |
Thanks Pete.
12-27-2019, 10:05 AM | #18 | |
Ps i did PM you. |
12-27-2019, 10:08 AM | #19 |
Member Wamey had install a sidecar on his Hawk. http://www.chinariders.net/showthrea...hlight=sidecar
Video https://www.facebook.com/wamey/video...5174836991394/
12-27-2019, 03:12 PM | #21 | |
I do believe , if it's still available, that a Velorex mount kit would shorten my fabrication time and frustration level . I'm thinking about a plate or bar with the lower tie ins that i can attach to the lower engine cradle area. Question now is can i just pivot the sidecar at the bottom mounts and make it a leaner ?, put the bike on the side stand and maybe a stopper of sorts ( R/H) so the bike can just lean in towards the side car on the stopper ? or is that now over simplifying this? If this is doable then do you slow the leaning with a basic shock absorber ( which if the right length can act as the stopper in both directions? Nice link Jerry Thanks again Paul |
12-27-2019, 03:24 PM | #22 |
Ebay has mounting kits. https://www.ebay.com/itm/UNIVERSAL-S...e1e7dbb9cc30c4
12-27-2019, 03:27 PM | #23 | |
China riders are a resourceful bunch so if any one has a lead that i did not dig deep enough to find please let me know . I live in Silver City NM 88061 and if i up my radius to 250 miles i think that puts me in range for Phoenix AZ , El Paso TX and Albuquerque NM . |
12-27-2019, 03:33 PM | #24 | |
Its time for a raise too |
12-27-2019, 03:46 PM | #25 |
Wait!! I'm suppose to get paid? I need to talk to upper management.
01-02-2020, 01:06 PM | #26 |
Hello,
I want a "sidecar", but not for animal or luggage. I want to basically have it as an outrigger so I can ride during the winter in snow. I try to ride to work everyday and missed 2 days last month because of snow. This place has something like I want for a Grom, but I would want a larger diameter wheel (I think) capable of what is typically my top speed on the commute of 50 mph. https://industrialmoto.com/utilitysidecars/ Goob |
01-03-2020, 08:06 AM | #27 |
Just for ideas
https://www.ebay.com/itm/2019-Honda-...c69a%7Ciid%3A1
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
01-04-2020, 06:06 PM | #28 |
jerry i had forgot to give you your yearly 50% raise but consider it done now! your next check will be for 50% more than you are getting now.
thanks... management
