Old 06-02-2019, 09:04 AM   #16
GronkFries   GronkFries is offline
There is no sellers bias here. The pumper carb is the only true "upgrade" in terms of any real measurable performance benefit. I wish I had a one stop shop when I bought mine., and I will recommend it over the mikuni for that reason.
I'm going to mess with my stock carb to gain some experience, but I can imagine a nice accelerator squirt would be advantageous. I don't think I've ever owned a bike that didn't have a pump. The stock carb on the TBR7 has an ok initial brap to it but poorly transitions to wide open power at such a disappointing level. The jet change that I'm doing today will benefit but I have a feeling I will be longing for that fine spray of ethanol free fuel at some point.
Old 06-03-2019, 07:18 AM   #17
paulsstag   paulsstag is offline
When you do your stock carb let us know if it is a #88 main jet and how many turns out the fuel mixture screw is stock and how many turns you need to make it run well. Also let us know if you shim the needle or replace it with an adjustable one ?
good luck.
Old 06-03-2019, 07:37 AM   #18
goat67   goat67 is offline
goat67's Avatar
Originally Posted by paulsstag View Post
Thanks jeffrey i will look it up.
I also cut off the bottom portion of the part the extends down about an inch using a dremel cut off disc
no more overflow leak.
2016 Brozz
Old 06-03-2019, 07:48 AM   #19
NzBrakelathes's Avatar
Motocheez did a video on it
Something like 2.25 turns out 105 main
That’s an ok starting point etc
Kits add more options and tuneablity just like any other PZ30
Old 06-03-2019, 07:50 AM   #20
good luck.
Check online same as hawk
It’s been shown over and over again as it’s all genetic
Old 06-03-2019, 09:54 PM   #21
good luck.
It is a #88 jet, and stock mixture was a turn and a half or so. Maybe less, I can't remember exactly. And yes, like nzbl said 2 to 2.5 turns out seems to be best for me so far. I ordered his kit didn't see any high speed jets (I might have lost them so I ordered it again), so it remains sluggish powerwise for now. The 17 tooth sprocket makes a huge difference and that was worth the money alone.
I will be tossing the stock needle and using the adjustable when the jet comes in.
Old 06-04-2019, 10:14 AM   #22
When did you order it? What jet configuration was on offer then? As a customer who bought an older version I’m fine sending a top up to the newer version
I’ll be in CT this weekend so if you want to extend the range of jets to the newer configuration just let me know n I’ll make it happen
Old 06-05-2019, 06:12 AM   #23
April 1st or 2nd I think. It's no big deal, I ordered another kit. If you have the two jets I need that would be cool though. Other than the stock pilot jet in the picture, this is what I got for brass (not sure what the two jets go to but didn't fit my carb):
Old 06-05-2019, 06:17 AM   #24
The main (left) is a #88 and the air/slow/whatever it's called can't remember what number it was. Maybe high 30's - I have seen where I may not need to change that one anyway.
Old 06-05-2019, 12:03 PM   #25
thanks for updating
thanks for the update on the carb and stock jetting, good to see nzbl includes an adjustable needle but surprised that you only got a single main jet? Does that pilot jet that comes with it actually fit the carb?
Old 06-05-2019, 05:35 PM   #26
Neither jets fit - I have seen older PZ30 aftermarket photos here that look to be what these are for. Our carb seems to be a newer model with a pressed in emulsion tube for the pilot and a bigger main jet outer thread diameter. We'll see what it all looks like when I get the new kit. Tempted to ream out the #88 but I don't have a drill press - If I end up drinking beers some night this week at my buddy's house I'll bring it over there and try it. Nothing to lose really, an 88 is worthless!
Old 06-05-2019, 05:38 PM   #27
And yes it comes with an adjustable needle - I think way better/easier than trying to negotiate shims with the stock one.
Old 06-05-2019, 08:51 PM   #28
NzBrakelathes
Just placed my order his afternoon with you on EBAY store.
You turned it around pretty quick...I'll be sitting by the mailbox waiting for my sprocket and main jets to arrive so I can get my TBR7 up to spec.
Best
Feldman
Old 06-06-2019, 09:50 AM   #29
Looks like the TBR7 has the short cold start jets then
New kits have a 40 and I’ve had those in some older versions too
I do offer more sizes as an option and I do have some smaller on hand but not many.
I’m in the west coast this weekend and land in Boston if that helps
Old 06-13-2019, 07:18 PM   #30
My kit came in and the bag had a lot more brass in it, including the jet I needed. This is what I got. The last photo is all I will be using lol (I like having extra stuff, the spark plugs will be handy and if anyone needs something let me know.):
