Old 06-26-2019, 10:03 AM   #16
PhildoScaggins   PhildoScaggins is offline
I just saw that guy selling the fuel injection kits for $500 for the 190. After seeing how intricate Glaveys post of doing it himself that $500 would seem worth it.
Old 06-26-2019, 02:46 PM   #17
scoot newb   scoot newb is offline
scoot newb's Avatar
Oh yeah, Mike Davis. I've been thinking about getting one. The problem is, I don't know how to tune it and none of the shops that dyno tune in my area will touch it.
Old 06-26-2019, 03:07 PM   #18
wlfpck   wlfpck is offline
Guy selling the kit is Mike Davis. His kit is pre-tuned for a zs190cc. May want to check his stuff out. If I'm not mistaken, I believe his also has ability to "self-tune".
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 06-26-2019, 03:11 PM   #19
scoot newb's Avatar
You're right. I had the name confused. I edited it. Mike Davis, I spoke with him and there is a 'base map' tune on it that may run well enough to get it to a shop that can tune it.
Old 06-27-2019, 06:48 PM   #20
Is this really a thing? I've never heard of having to do that. If so, is there a household cleaner I can use?
Old 06-27-2019, 07:33 PM   #21
scoot newb's Avatar
Which part? Using the oil filter grease/spray or cleaning it?
I saw a video on YT showing Dollar Store Totally Awesome cleaner cleaning a Uni-filter. I bought some and it worked as advertised. Using the grease... yeah back in the day with dirt bikes.
https://www.amazon.com/UNI-Foam-Filt...dp/B0022ZN68Y/
Old 06-27-2019, 07:38 PM   #22
I guess cleaning it. I havent added any grease, why would I need to wipe it down?
Old 06-27-2019, 07:40 PM   #23
scoot newb's Avatar
For oil cutting solvent you can use rubbing alcohol. But don't use that on the foam just the rubber part that connects to the carb.
The grease helps keep dirt and other particles from getting sucked through the foam. Mine didn't come with that sticker and I don't use grease on mine but it couldn't hurt.
Old 06-27-2019, 07:43 PM   #24
scoot newb's Avatar
Oh. I think they mean clean it down after applying the grease spray to the filter element to prevent a gob from getting into the motor.
Old 06-27-2019, 07:53 PM   #25
Thanks. That makes more sense. It wasnt greasy, the warning had me confused. I got some stuff to fab up a bracket to get this exhaust on. Hopefully I will be in business soon!
Old 06-27-2019, 07:59 PM   #26
scoot newb's Avatar
Nice! Post some pictures of your ride
Old 09-13-2019, 02:53 AM   #27
scoot newb's Avatar
I stuffed a Harley LED and bucket into a Monster Eye bracket. I like it. It is bright and looks better IMO. I just need to trim the back of the bucket so more wiring can fit behind it. I added a used Vader font fender. It has a crack.
Some new items arrived. I like 17 34 sprocket ratio and decided to go to 16 32 and from 428 to 420. Less weight less spinning mass right?
I also got some tires
Coming Soon
What do you think?
Old 09-14-2019, 02:48 AM   #28
Whisky   Whisky is offline
Whisky's Avatar
Your really going to town, new tires too and good choice, cant wait to see the new rims mounted, soon I hope? Are u running the rear 32t now? how is it compared to the 34t? I have a 32t debating weather to change or not, I'm sure there's still plenty of torque? I don't want to run a 17 on the front, not enough room like there was with the 125.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 09-14-2019, 06:37 AM   #29
scoot newb's Avatar
It's still 17/34 on there now. I am going to swap everything over once the rims come. I am pissed off. My horn isn't working.
Old 09-14-2019, 07:41 AM   #30
Whisky's Avatar
Your running a 17 on the front? That's a very tight fit. I think going up 1t in front is the same as going down 3 in the back. I could be wrong though. I've never used my horn, I suppose I should see if it works.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
