03-07-2008, 12:59 PM | #16 | |
03-07-2008, 01:08 PM | #17 | |
03-07-2008, 02:43 PM | #18 | |
03-07-2008, 04:08 PM | #19 |
I tend to agree with JIM.
From what I have seen on the new counter balanced models is they also reworked the rear-upper engine mount to the way it should have been from the get-go so I'm only assuming they fixed the lousy engine to frame fit they had in the earlier bikes and put in the PROPER size bolts. Still the engine mount is such a critical thing that I'd be eyeing up a new model bike engine mount just to make sure it was right. |
03-07-2008, 04:09 PM | #20 |
Guest
Posts: n/a
there was no play in the clutch cable. they corrected that and tightened chain and the shudder seems to be gone. There are less vibes now. But i have some issues with my rims being a bit off. I am not sure how to correct that problem easily. If anyone knows of a thread on here or somewhere else that can instruct me how to work on rims please let me know.
thnks |
03-07-2008, 04:36 PM | #21 |
I had a counterbalanced engine in my gy5 apparently it was a supposed grey market from Lifan wholesalers. And the tranny did take a dump at 1600km. The good news is that they agreed to replace it (I'll believe it when i see it) I did replace the engine with a ohc motor I got on ebay and it doesn't seem to vibrate anymore than the counterbalanced motor did. My problem now is my crude attempts to make a bracket for the front mount. Oh fyi I never had a single bolt rattle loose and I only did minor locktiting of the bike. Maybe I should have pour some locktite in the transmission.
03-07-2008, 05:01 PM | #22 | |
03-07-2008, 05:38 PM | #23 |
Guest
Posts: n/a
Well...10 miles later the vibration is back (if it was ever really gone, may have been my imagination) and is now accompanied by a strange clicking sound as I come to a stop with clutch pulled in.
this totally sucks...i dont trust it to ride anymore and has only 1000 kilometers on it. |
03-07-2008, 05:45 PM | #24 |
Sounds like it is almost in a gear, Kinda like when You don't catch neutral right?? sounds more and more like that trannie is defective.
03-07-2008, 05:51 PM | #25 |
Guest
Posts: n/a
well I am taking it to them tomorrow so they can check it out thoroughly. it bites though because this is my only form of transportation atm. my problem communicating to the mechanic doesnt help. I know so little that I doubt they take me seriously. They are going to have to take it out and get it warm and see for themselves. The good thing is, I know for sure they will make it right. I have no doubt of that. Just sux that I am stuck riding bicycle or bus or freakin' walking.
03-07-2008, 06:39 PM | #26 | |
Here's a how to I found: http://www.webbikeworld.com/motorcyc.../spoke-wheels/ You can tighten the spokes with the wheels still on the bike and the tires mounted (gotta keep in mind that a spoke that's too long can puncture the tube!), or you can unmount the wheels from the bike, insert the axle through the wheel and clamp the ends of it to some jackstands or anything solid enough to hold steady. The link seems to have good directions, I learned how to do it at an early age (11 or 12!), so it's not too hard. Just go slow. Oh yeah, a half turn at once is too much! 1/4 or 1/8 turn is about right once the spoke begins to tighten and you tighten them in pairs as they alternate sides around the hub. |
03-07-2008, 10:56 PM | #27 |
Guest
Posts: n/a
if some are too tight and others are too loose can I loosen them all and then tighten them up one by one and get it even close to straight?
03-09-2008, 01:17 AM | #28 | |
Just work on the loose ones and be mindful of keeping the rim true, when you tighten a couple of spokes, spin the wheel and watch the runout in both directions, check the tension on ALL of the spokes periodically as you work, go slow and you will be fine. Find a how to online and follow just that one, but if you run into trouble just ask. It's not hard to do. Just remember that once you start getting some tension in the spokes, MAKE SMALL ADJUSTMENTS! 1/4 turn can be big, 1/8th is better. |
03-09-2008, 04:29 PM | #29 |
Guest
Posts: n/a
Well, I am now fairly certain that the vibration is isolated to the engine. I went up on rt 250 where its hilly. One the way down at 45mph with bike vibrating like mad, I pulled in the clutch and whallaaa the vibration is gone. Therefore, the vibration is not tire related!!! or rim related !!! and...btw...after just a few more miles..its worse now than ever.
03-09-2008, 07:00 PM | #30 |
could be the transmission, check with your dealer..
also I suppose this is more of a rattle then a vibration, but my muffler insides rattled to pieces...
