Old 01-12-2019, 05:51 PM   #16
jsumd   jsumd is offline
jsumd's Avatar
That is badass, sir. Welcome
2002 Harley Davidson XL883R
2012 Yamaha FZ6
2022 Hawk 250
2002 Yamaha R6 *sold*
Vader 125cc *sold after owning for many years*
1997 Jeep Wrangler *sold due to frame rot*
Old 03-03-2019, 03:15 AM   #17
Nandor   Nandor is offline
Nandor's Avatar
Heres so updated pictures of the work thats been done, replaced and painted basically everything on the front end.
New shocks on there way and tank off to be painted before frame gets rebuilt and powdercoated
Old 03-03-2019, 05:30 AM   #18
Nandor's Avatar
Few more
Old 05-05-2019, 12:59 AM   #19
Nandor's Avatar
Well turbo is finally here, working out mock up piping, oil tankand fuel and oil pumps. Once im happy with piping ill get it mandel bent and start welding it. Then it will b heat wrapped
Old 05-05-2019, 10:13 AM   #20
wedooit   wedooit is offline
wedooit's Avatar
Yup bad ass! welcome!
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome".
Old 05-06-2019, 10:44 PM   #21
paulsstag   paulsstag is offline
Do you have a link to the turbo you purchased ?. Thinking about something like that for my TBR7 not so much for the power but for altitude compensation as i'm riding between 6 and 8000ft. i think it takes about 3 psi to get to the equivalent of sea level which should be fine.
Old 05-06-2019, 11:17 PM   #22
Boring
If I had to guess, it is an IHI RHB31 VZ21, or a copy of one. Pretty much the smallest production turbocharger on the market. They can support up to a max of 100hp, and run on engines down to about 125cc.
Old 05-07-2019, 06:38 AM   #23
Your the man Thanks for the info. Also i have been following your updates on your black hawk ( not your helicopter , as i think you'll post details on that later ) . Nice to see what you have done and the reasons your doing things, Please keep us updated on the chain tensioner as in how it helps or not and how it holds up. Thanks again Megadan.
Old 05-09-2019, 04:25 AM   #24
Nandor's Avatar
Yes as stated, its a vz21 turbo. These turbos run 7psi stock.
I have been doing alot of research and have decided to go blow through carb set up as most people could see by the pics. This requires the fuel bowl to b equally pressurized equal to boost pressure. Also needs your bowl vent in inlet side of carb to b blocked off or fuel will flood out of it
Old 05-09-2019, 04:45 AM   #25
Nandor's Avatar
Few updates of the mock dump pipe and screamer pipe
Old 05-10-2019, 09:58 AM   #26
PhildoScaggins   PhildoScaggins is offline
I noticed the straight axle, how does it turn? Do you do sweet doughnuts with it?!
Old 05-15-2019, 12:00 AM   #27
Nandor's Avatar
The straight axle turns great on dirt. Really doesn't cause it any troubles at all. Ive had it on hard surfaces and it turns almost aswell.
Oh yeah does make for good donuts does them in second
Old 05-15-2019, 11:16 AM   #28
Would you be so kind as to give us a turbo carb prep tutorial? Pics of the necessary mods would be most helpful. Thanks!
Old 05-16-2019, 06:42 PM   #29
Nandor's Avatar
No a problem, be more than willing to show u all how it goes together. Will b a while till i have all the necessary bits all plumbed and wired for this and need to finish all the frame with mounts and get it powder coated.
Might even dyno it for a laugh
Old 05-19-2019, 02:40 AM   #30
Nandor's Avatar
Well made a bit of progress on the weekend.
Made a reducer to go from turbo to carby
Polished compressor housing
Tacked up carby manifold ready for welding
Got all pipe work in right place and tacked so now can go down and get it all mandrel bent
Ordered black stainless braided lines and connections and mocked up where they will run
And decided on placement for filter, battery, oil pump, oil cooler and accelerator cable of course cable needs shortening and a 90° bend into top of carb.
