Old 03-04-2019, 03:37 PM   #16
motoracerx   motoracerx is offline
Originally Posted by Whisky View Post
I'm guessing that's where that bracket goes? I really want to put my 17t front sprocket on but don't want to buy a new chain right now.
So what exhaust is this? Any other suggestions for hellcat?
Old 03-04-2019, 08:15 PM   #17
Here is an EBaY link to the version I used https://www.ebay.com/itm/Stainless-S...72.m2749.l2649
There are others available on Ebay for a bit less money, i went with the full stainless because i hates rust lol. If you poke around on this forum a bit, you can find some additional links to this same basic exhaust .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 03-06-2019, 12:18 AM   #18
Whisky   Whisky is offline
Whisky's Avatar
zs190 will be here fri. will have to sit until weather warms up some unfortunately, also another new exhaust GP1 from motokit.com. Will be installing new swing arm at some point. The list goes on and on.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 03-19-2019, 12:14 AM   #19
scoot newb   scoot newb is offline
scoot newb's Avatar
Do you know if that pipe will work on the Hellcat? The exhaust port on mine tilts to the right. I can't tell if yours does too.
@RedCrowRides
I'm glad I saw your post about the 115 main. I recently installed a VM22 and deleted the air box. It was not running right with the 110. Hopefully 115 will get it sorted.
Old 03-19-2019, 03:20 AM   #20
scoot newb's Avatar
.... I really want to put my 17t front sprocket on but don't want to buy a new chain right now.
Dang, I thought I could use the stock chain and just push the rear tire forward a bit. Three teeth make that much difference?
Old 03-19-2019, 11:11 AM   #21
RKG83   RKG83 is offline
I put in a 17t front sprocket and didn’t need a bigger chain, stock one worked on a boom.
Old 03-19-2019, 12:43 PM   #22
Whisky's Avatar
It all depends, my bike was new when I put the 17th on , the tire was all the way forward, if your bike has some miles on it the chain would have stretched some. That's why no new chain was needed. The stock #420 stretches alot, I changed to a #428 for that reason.
Exhaust will fit on your bike.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 03-21-2019, 03:49 AM   #23
scoot newb's Avatar
I think the Hellcat comes with a 428 chain. I don't know for sure but I saw this.
Old 03-21-2019, 07:46 AM   #24
Whisky's Avatar
That's could be an upgrade but I don't know, mine didn't but the back sprocket is a 428, I thought that was strange.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 03-21-2019, 04:05 PM   #25
scoot newb's Avatar
I just got the 420 sprocket and compared it to the 428. The 428 is a bit thicker. I guessing if you had a 428 rear sprocket a 420 chain wouldn't fit or be really tight. IDK. It's raining out now but eventually I'll see how each one fits on the chain. If only I had something to measure the pin length and roller diameter I'd know for sure.
Update. I went out and inserted both sprockets into the chain and compared them to the rear sprocket. The rear sprocket is definitely 428, when I insert the 420 into the chain there is a lot of wiggle room. It doesn't look right. I'm guessing mine came with a 428 chain.
Old 03-21-2019, 10:24 PM   #26
Whisky's Avatar
I could be wrong, maybe mine did come with a 428 chain
but I bought a new 428 chain w/ O rings when I changed sprockets.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
