Old 05-26-2018, 11:45 PM   #16
Cravin01   Cravin01 is offline
Cravin01's Avatar
I'm glad to hear I'm not off my rocker , I've been contemplating a larger carb even before I received the bike. The power jet seems like a good option along with a upscaling.
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 05-27-2018, 01:37 AM   #17
Originally Posted by Ariel Red Hunter View Post
Megadan, remember that Keihin carbs are described by the diameter of the air cleaner side while Mikuni's are described by the venturi diameter. a VM 28 is equivalent to a 32 mm Keihin. However, the Keihin shown in the link has a starting jet instead of a choke which should give improved performance above 3/4 throttle even with the 30mm model...ARH
These aren't traditional PWK's though, but knock off copies. They are literally a 30 or 32mm bore at the spigot, just like my VM30 is. I have all three if you want a side by side by side lol
Old 05-27-2018, 01:40 AM   #18
You cold give it a try. I would be interested in the results of a 30mm bore carb on an unported CG250 head.
That is something to keep in mind with Jerry's experiences on this carb, his head has been ported and decked.
Old 05-27-2018, 12:17 PM   #19
If you look at the pz30 at the flanges end it measures 30mm but tapers down towards the slide. So technically it's not 30mm all the way through. Stock intake manifold is only 28mm at the head. Pwk30 is 30mm all the way through and the intake adapter is 30mm at the head. I did check that the head and manifold are port matched.
2004 Honda ST 1300
Old 05-27-2018, 01:10 PM   #20
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
The TT 250 has a Keima version of a Keihin carb and it was very easy to rejet and tune.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18.
Old 05-27-2018, 01:20 PM   #21
is the idle mixture screw on the side? I thought it was on the bottom like the pz30.
2004 Honda ST 1300
Old 05-27-2018, 01:30 PM   #22
Idle screw is on the side. It is a different model but it is a Keima and uses standard Keihin jets. https://www.cscmotorcycles.com/Articles.asp?ID=294
Old 05-27-2018, 01:34 PM   #23
That is the idle speed screw, aka curb idle. He is talking about the idle mixture screw. That is located on the bottom of the carb, back side of the bowl between the two bowl screws.
Old 05-27-2018, 01:39 PM   #24
Yes the screw that is shielded by an impossible to remove domed brass plug. I tried to drill it I tried to use a punch and nothing would budge it so the idle speed mixture stayed stock and I just adjusted the needle and changed the main to a 115 and left it at that.
Old 05-27-2018, 02:30 PM   #25
Lifanda requires a different bend at the intake tube, unless I ditch the battery box location. Jerry and Dan, are you aware of a bend that pitches the carb to the other side?
Old 05-27-2018, 03:49 PM   #26
I am fairly sure that I saw some that angled the other direction in my searches, but I would have to look around again to be sure.
Old 05-27-2018, 10:12 PM   #27
Yes Weld, I've ran across some while searching. I'll look through my search history and see if I can find them.
2004 Honda ST 1300
Old 05-28-2018, 10:26 AM   #28
Cravin01's Avatar
Well I cant seem to be able to decide if this is worth my while, I read that a 4 stroke doesn't need a power jet but it never said it wouldn't give a improvement if used.
As always Dan threw in some valuable info about the carb and I will not be decking my head but I could polish the exhaust port myself, so I thought maybe I should look at the Keihin PWK28 ...But I'm not positive going to a power jet and a slide valve will give the desired improvement over the butterfly valve in the PZ30.
Opinions please!
2017 Bashan Storm
Old 05-28-2018, 11:52 AM   #29
Okay Weld, I did some searching. Most of the ones I ran across were for a spigot mount carb. The one I did find for flange mount would be too small. 26mm. What kind of freak of nature you got? lol.
2004 Honda ST 1300
Old 05-28-2018, 12:00 PM   #30
Yep, same result on my part. If you want a spigot mount carb, you are covered. Flange mount, not so much. I swear at one time I saw some 30mm flange mounts, but now I can't find them.
