Old 04-08-2018, 05:24 AM   #16
Not a big deal with the wrong oil type. Maybe change the oil a bit sooner for the next go around just to ensure you got the rest of the "bad" stuff out, but it should be fine.
As far as the oil leak. Is it at the head gasket or the base of the cylinder where it meets the engine cases? This seems to pop up from time to time. You can check the head bolt torque to make sure one or two aren't loose. This will require taking the rocker assembly off, but it is pretty easy - 3 bolts. Then you will see the 4 head bolts. The torque spec is kind of generalized, but I have my head set to 28ft-lbs. Just go over them in a cross cross pattern like you would a 4 lug car wheel.
If that doesn't stop the leak then either the head gasket or base gasket may have been damaged during assembly. You can buy both as a pair for about 10-12 bucks on ebay.
As far as the bike starting, running, and sounding better. It's amazing what a proper valve adjustment can do ain't it?
The running issues you are experiencing aren't uncommon. To really get it to run properly it will require upping the main jet size to at least a 105, shimming the needle with at least 1 shim, and uncapping and turning the idle mixture screw out to around 1 1/2 turns from seated. This is a pretty good baseline carb setup for most stock Hawks and Magicians.
Old 04-08-2018, 11:44 AM   #17
pcast01   pcast01 is offline
Thanks for all your insightful information. I tried to get it running and with no luck. The bike won't stay on without constant throttle with the choke on. So what could be the most likely culprit?
Old 04-08-2018, 01:15 PM   #18
Well, in general, it's too lean. If you leave the choke on until it is hot and then open the choke up (turn it off) does it run better, or does it only ever run with the choke on, no matter what?
Old 04-08-2018, 01:27 PM   #19
I can only keep it running with the choke on. I stayed at least 10 to 15 mins and I couldn't keep it running on half choke.
Old 04-08-2018, 01:28 PM   #20
That makes me suspect a vacuum leak. Check the condition of the O-ring seals on the intake to the head surface, and on the carb to the intake surface. Check the intake over very well for any rips, tears, or holes in the rubber and that the flange surfaces on it are flat.
Old 04-08-2018, 03:47 PM   #21
O-ring in Carb
Well I looked at the O-ring on the carb side and found this above.
I didn't pull out the other O-ring yet but it was snug in the seal.
Old 04-08-2018, 07:07 PM   #22
Looks like you found the problem.
2004 Honda ST 1300
Old 04-08-2018, 07:28 PM   #23
Where can I find the same O-ring size at?
Old 04-09-2018, 05:11 AM   #24
I am fairly certain there is a Honda OEM O-ring that is the same size, but you have a couple of other options.
You could buy this kit, which includes an O-ring that will work. https://www.aliexpress.com/item/1Set...ceBeautifyAB=0
Otherwise, if you can measure the inside diameter of the O-ring, and a rough thickness I can try to hunt down a Honda part number that will work.
That, or head to your local parts store and try to match up an O ring that can work.
Old 04-09-2018, 09:57 AM   #25
You should be able to match up the o-ring at your local hardware store or auto parts.
2004 Honda ST 1300
Old 04-09-2018, 11:21 AM   #26
Harbor Freight is likely to have an assorted o-ring kit that'll have a match.
Old 04-09-2018, 03:05 PM   #27
Thanks guys! I am headed to an autozone after work and try my luck there.
Old 04-09-2018, 10:20 PM   #28
Cravin01   Cravin01 is offline
Cravin01's Avatar
I'm with Weldangrind, Harbor Freight has a nice package of O-rings in a plastic case, maybe they have the right one?
https://www.harborfreight.com/180-pi...kit-67525.html
Old 04-10-2018, 10:09 AM   #29
Ariel Red Hunter's Avatar
I think those are in mm. There aren't any in that package that are big enough...ARH
Old 04-10-2018, 10:18 AM   #30
Cravin01's Avatar
Maybe these but I cant remember if I actually seen them in the store.
If you use the slide bar below the picture you can zoom in and see the sizes that are in the box.
https://www.harborfreight.com/397-pi...ent-67580.html
magician 250cc
