04-01-2018, 09:29 PM | #16 |
amazon $40 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
but I did have to open the inside diameter on a lathe to fit the lip of the hub inside. the wheel spacers do not have a lip to truly support the rim the rim is just riding on the bolts so make sure they are always tight and don't beat them too hard |
04-02-2018, 10:19 AM | #17 |
This is normal for a manual trans bike. You have to be moving to click straight through the gears. It's just more noticeable on a quad because you can't rock it a little like a two wheeler. Mine seems more "sticky" but it's just if I'm sitting.
04-02-2018, 05:34 PM | #18 |
I was able to build the hitch today just have to sand wash prime and paint now
Attachment 12485 Attachment 12486 Attachment 12487 Attachment 12488 Attachment 12489 Last edited by PANDEMIC; 02-01-2019 at 09:35 AM. |
04-02-2018, 05:38 PM | #19 |
04-03-2018, 10:05 AM | #20 |
Dang! I have one of those racks too! That's a great idea!
04-04-2018, 12:52 PM | #22 |
rhino light question
does anyone know what color the wire for the brights is my wire tester broke
04-08-2018, 08:54 AM | #24 |
so I finished my trailer hitch it is all painted now. instead of using u-bolts I used the brackets that held the rear axle to the metal crate the atv came in
Attachment 12586 Attachment 12587 Attachment 12588 Attachment 12589 Attachment 12590 Last edited by PANDEMIC; 02-01-2019 at 09:35 AM. |
04-08-2018, 08:59 AM | #25 |
then I added a 20" led light bar. I tied the light into the brights so I would not have to add extra switches.
Attachment 12591 Attachment 12592 lights on Attachment 12593 brights on Attachment 12594 Last edited by PANDEMIC; 02-01-2019 at 09:35 AM. |
04-13-2018, 02:40 PM | #26 |
So I had some leftover truck bed liner and acid primer so I took some of the metal crate and painted up some Ice shanty and sled pin hitches then built the pin using a ss bolt steel spacer on the bolt lock nuts and washers and a pin to lock it in place
Attachment 12641 Attachment 12642 Attachment 12643 Attachment 12644 Attachment 12645 Last edited by PANDEMIC; 02-01-2019 at 09:35 AM. |
04-15-2018, 01:08 PM | #28 |
So I tested the trailer pin hitch on the sled today works great. The rhino did not want to grip on the ice and snow i will need chains for it before next ice fishing season
Attachment 12676 Attachment 12677 Last edited by PANDEMIC; 02-01-2019 at 09:35 AM. |
04-15-2018, 01:31 PM | #29 |
Did you try airing down a bit? I installed tubes in my quad, so the beads wouldn't pop at low pressures.
04-17-2018, 11:42 AM | #30 |
no looking into studs or chains and putting skis on the front for next winter.
