Old 11-21-2017, 08:49 PM   #16
Jay In Milpitas's Avatar
Originally Posted by jaydoan View Post
I have exact the same problem, and think that it's clogged fuel injector, too. I'm new here. can anyone point me to how to clean fuel injector in 2015 RX3. Thanks
USE FIRE PROTECTION SAFETY HERE.
Remove the injector, then crank the engine while watching the injector. It should emit a nice fine spray. If it does, your injector is clean.
If it dribbles and spits, then cleaning is needed.
Horse holder at Madame Orr's House.
Old 11-21-2017, 08:51 PM   #17
Originally Posted by RX3James View Post
Ok sorry it took so long to get back to you all.
1st replaced the battery the other one was toast.
2nd replaced the spark plug the old one was very dirty.
3rd yes the fuel pump is spooling up every time I turn the key over.
It turns and turns and turns but it won't light off.
Every 5th or 6th time I try to start it, it will turn over and sputter then die. The rest of the time the starter just turns and turns..
There is gas in the bike and I've checked all the connections I have no idea where else to look...
This is getting beyond frustrating...
While you were replacing the spark plug, did you check for spark?
