#16 | |
It will have programmable: Tire circumference 100cm to 250cm so suits any wheel/tire combo and accurate within 2% or so (you can adj calibration) Fuel gauge or can be used as volt gauge, Bross style will have a fuel and volt gauge displayed at the same time. Other style will have a digital volt meter after TRIP. Over speed warning function. Adjustable number of pulses from magnates. Miles or KM PH |
#17 |
Should fit just check if both end are internal or external threads, or inner cable might be same lenght
#18 |
Should fit just check if both end are internal or external threads, or inner cable might be same length
#19 |
When I bought my used Hawk the stock cluster was broken and the cable was missing. I first installed a Trail Tech Enduance I but I felt it was lacking in a few areas. I pulled the trigger on the digital cluster and now I am completely satisfied.
The stock cluster is going to fail eventually. So I would recomend, like many others here, the digital right from the start. |
Tags |
cable, fix, maitenence, repair, speedometer |
