Old 08-06-2017, 04:47 PM   #16
KingPrimusIII   KingPrimusIII is offline
KingPrimusIII's Avatar
Thanks for starting this thread, Sully. I thought it was just me! I'll be watching/will share any info I find.
"You think life is crazy now? Just wait until the internet arrives!" -Albert Einstein
Old 08-08-2017, 08:53 PM   #17
jimwildman   jimwildman is offline
jimwildman's Avatar
From;
http://www.kazumapower.com/cg250-ver...e-p-11501.html
This engine uses HONDA style clutch discs and we stock/ship a high performance clutch fiber disc kit by CLUTCH FACTORY.
there is hope!
Old 08-08-2017, 09:44 PM   #18
Ariel Red Hunter's Avatar
Originally Posted by jimwildman View Post
From;
there is hope!
YES! If they have after market clutch plates (fiber discs), they should also have higher quality clutch springs as well....ARH
Old 08-09-2017, 08:25 AM   #19
jimwildman's Avatar
I'm hoping to find more info about "HONDA style clutch" for a full swap.
All the XR clutches Iv'e seen have a 4 spring basket, so It's a bit confusing as to what Honda.
Old 08-09-2017, 08:34 AM   #20
Sullybiker's Avatar
They're KG kits (AKA 'Clutch Factory') by the sound of it; if you look at parts they mention that they're 5 plate but that they will ship an extra plate for the '250' class engines.
Old 08-11-2017, 02:11 PM   #21
jimwildman's Avatar
EBC Products..
http://www.whygostock.com/clutch-for...c-200cc-250cc/
http://www.whygostock.com/clutch-spr...chinese-motor/
Only 4 springs though,, so again Im confused.
Old 08-11-2017, 02:21 PM   #22
Whether it has 6 springs or four springs doesn't really matter. What matters is if the clutch plates fit the basket, and that your current steel plates are not warped....ARH
Old 08-11-2017, 02:23 PM   #23
Sullybiker's Avatar
Some dimensions at least, that's useful. It looks like it's just the fibre plates and not the steels? Am I reading correctly?
Old 08-11-2017, 02:27 PM   #24
Yes, you are. If you have warped steel discs, you'll have to replace them....ARH
Old 08-11-2017, 03:12 PM   #25
jimwildman's Avatar
If you use the search and put in steels a few come up but not anything specific to our bikes.. I may send an email and ask..
I was hoping to find clutch disks, steels and springs to replace the originals.
So I have questions on the spring packs too since ours have 6, this and most Honda's use 4. I would guess the springs in a set of 4 are stronger than in set of 6.
so even if they fit ordering 2 packs and using 6 of the springs would likely make the clutch too stiff.
Ill send an email and see what kind of response I get.
Old 08-11-2017, 08:38 PM   #26
pete   pete is offline
pete's Avatar
Google ..... Moose racing Clutch easy pull....
there are cheaper ones on alliexspress ===> https://www.aliexpress.com/item/CNC-...AbTest=ae803_1
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-12-2017, 05:49 PM   #27
crackerjac   crackerjac is offline
Sorry this might be a bit off topic but I'm reassembling my stock Zong 250 clutch and was wondering why the top two fiction plates are in the short slots while the rest are in the long slots? Any benefit to this or is it better to put them all in the long slots like most other bikes? Stock clutch photo below.
Old 04-08-2018, 09:03 AM   #28
Its_not_a_honda   Its_not_a_honda is offline
Did you ever find out?
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 04-08-2018, 01:19 PM   #29
I honestly doubt it would make a difference where those tabs are. As long as they are free to move and don't get stuck or bind on anything, the stack pressure will stay even.
They may have done that setup to reduce chatter, or maybe as a way to help with clutch operation when things expand. Or both, or neither.
Old 04-08-2018, 09:31 PM   #30
I was just wondering. Thanks for the info MD!
I think I might have a clutch problem. Apollo DB36. No mods yet other than a 12 tooth sprocket. I have ridden dirt bikes most of my life at one time or another. I have no problem tearing into the gear box. I am very mechanical so I actually look forward to working on my bike.
When I really get on it from a slow speed, it goes but I feel like it should have more instant gumption. Like pull the front wheel kind of gumption. I have went down from a 14 to a 12 tooth front sprocket. I have ordered but not installed a carb with an accelerator pump. The bike does great on trails and has great power for what it is. I just have always done wheelies on any bike Ive ridden. I mean "stand it up and ride it on the back wheel" wheelies. Not pull it up for a few inches for 5 feet. This bike has that power but it does not get to the back wheel. I thought it was the gearing but the 12 tooth didn't do it. I have tried it on the pavement too. Nothing but go forward. It is like a linear feeling power. Almost like a torque converter type feel. On the trails I have never needed any more power going up hills or through anything. BUT when I come to a fallen tree, a rock, stump, or ditch where I need the front wheel up to get across, nothing happens. I just have to run into it and hope for the best. lol
I have checked the rear wheel for slipping on the tire It is locked tight to the rim. I figure it has got to be the clutch at low rpms just not grabbing. I do not feel any chatter. I am running T4 oil. I change it after every 2 rides. Cable adjusted properly. Bike was delivered in January 2018 so it is pretty new. I would not say it is completely broken in but well on its way. I am kind of hoping it is just the clutch assembled wrong or something along those lines. Anyone else having this problem? Any ideas?
