Old 06-19-2017, 01:48 PM   #16
wamey   wamey is offline
wamey's Avatar
Originally Posted by Kdburtch View Post
awesome write up, thank you. Does it completely clear the knobbies, or is there some rub?
Totally clears! If rub happens, I've got other problems
Old 06-20-2017, 01:58 AM   #17
hertz9753's Avatar
Is that a soft terrain off road tire?
Old 06-20-2017, 10:49 AM   #18
wamey's Avatar
It's the tire the hawk came with. I'm planning on switching over to kenda's after these wear out.
Old 06-21-2017, 02:00 AM   #19
hertz9753's Avatar
My Hawk front tire looked like that.
Old 09-30-2018, 01:27 AM   #20
mj435   mj435 is offline
mj435's Avatar
So I just got my new hawk and the fork is horrible? I can move the front wheel back in forth in the forks and it makes me feel like I'm riding with two flat tires.
Old 09-30-2018, 12:30 PM   #21
kirbo7106's Avatar
Thanks Wamey! Great post with pictures! I bought the same brace, but I haven’t mounted it yet.
Enjoy the Ride!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 09-30-2018, 12:53 PM   #22
ben2go   ben2go is offline
Your stem nuts are probably loose. The front tire needs to be set properly and the axle nut torqued. The triple clamp bolts need to be torqued properly as well. None of these should need thread locker as long as they are torqued properly. If you're not very familiar with motorcycles and their mechanical workings, you shouldn't have bought into the China bikes.
Old 10-01-2018, 08:37 PM   #23
If the wheel is sliding back and forth between the forks I would start by making sure you didn't forget the left side axle spacer that sits between the wheel and left fork.
Old 05-02-2019, 09:02 AM   #24
LaGwAgOn6040   LaGwAgOn6040 is offline
Head Scratching
Anyone have any other links where to buy that fork brace? Seems the eBay seller doesn't have them for purchase anymore.
Old 05-02-2019, 05:00 PM   #25
This is their actual website listing. They are out of stock here as well, but you could contact them and see if they have any on order. https://www.demonscycle.com/chrome-s...ide-front-ends
Otherwise, there are other fork braces made for the same bike that would also work.
Here is an example for about the same price, just unpainted/plated. http://www.wpsracing.com/ulfobrrawkok.html
Old 05-02-2019, 11:16 PM   #26
roundhouse   roundhouse is offline
roundhouse's Avatar
I bought one right after reading the original post and just have not drilled holes in it and installed. Maybe this weekend.
Old 05-07-2019, 05:37 PM   #27
surfhawk   surfhawk is offline
I know this is an old thread, but i'd like to add something. First, thanks so much for the great idea including part details. Made it very easy.
I painted mine black to make it blend in with the tire more.
Also, if you raise the front wheel and loosen the axle nut, you can get the brace in and use slightly longer bolts to coax the brace in place enough to then sneak in the original bolts at the other bolt hole. No need for ratchet straps or removing the front fender. Looks great and bike feels more stable. Thanks for the idea!
Old 05-07-2019, 05:38 PM   #28
oops, i guess pic didn't attach first time. Sorry
Old 05-07-2019, 07:34 PM   #29
I didn't have to even use longer bolts to get mine into place. I think my only complaint is that the brace puts outward pressure on the forks. I used my vice to try and tweak the ends together a little bit to reduce that. Another option would be to drill your new holes a bit higher up than the original holes and have less air gap over the tires. This would reduce the interference with the widest part of the fork and make it a bit easier to install. Then you could trim off the bottom to reduce the size and weight.
Old 05-07-2019, 10:18 PM   #30
with your vice were you able to squeeze the round part at the top? That's the widest part on mine putting outward pressure on the forks. The ends are actually easy enough to bend with my hands, but that didn't help the top round part. Thanks.
brace, front forks, hawk, suspension
