#16 | |
I'm with you megadan, that Dupont stuff is the best I've ever used. Lubes well, lasts a while and doesn't end up all over your bike. Usually any time I place and Amazon order, I'll toss in a can to ride the coattails of the free shipping. Can't have too much.
#17 |
I use RK chains. Theyre good and price a little cheaper than D.i.D. chains.
#18 |
After reading this I decided to go out and measure my chain to se how much the stock chain has stretch. Good rule of thumb is a that anything over 2% of stretch is out of tolerance and needs to be changed and on an o-ring chain it's 1% of stretch. A 428 chain is 1/2" from pin to pin. I have just over 1700 miles on the stock chain. Measuring 23 pins it was just under 11 9/16". That's right at 1%. The chain doesn't actually stretch but wears the pins and bearings which causes the excess play. The stock chains aren't well lubricated from the factory like every other part on these bikes. When I assembled my bike I took the chain off and let it soak in synthetic gear oil for a few hours while assembling the bike before I put it back on the bike. This is more than likely why my stock chain has held up so well. When I do go off road and go through lots of water, mud and sand I pull my chain off when I get home and clean it with kerosene. I'll wash it 2 or 3 times to make sure I have all the sand and grime out. After it dries i'll either soak it in gear oil again and lately I have use ARH method and boil it in paraffin wax. I found this method works so much better and pretty much water proofs the chain and is not as messy. When I do replace the chain i'll go with the Unibear chain.
#19 |
I've been running a 128 link chain on my TT 250 with a 17/45 setup with no issues.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
#20 | |
#22 |
Maintain it correctly and you will get a lot of miles out of it. Not a big deal to get 25,000 miles out of one with a moderate powered engine.
#23 |
If your hard on the bike the 428 chain will stretch badly. oring, xring, not much better.
if your wasting money due to short life just go 520 Some people will warn about rotating mass and such but really, if you dump the clutch at WOT often, to get over logs and up rock faces like I do, you will need this upgrade. For the hawk, and many other Chinese bikes. look into. jtsprokets jtr279 rear jtf328 front I ordered 13tooth front and 38 tooth rear. Use a good oring or xring 520 chain, I'm not sure yet how long but I got a deal on one way too long. I'll update this post after I cut it to length. I plan to wreck the 428 I have on there now prior to this install. My goal was to match my existing ratio with a 428 setup of 17/50. The 13 tooth front 520 sprocket is almost the same diameter as the 16 tooth 428 sprocket. and matches otherwise. The 38 tooth 520 rear is a bit smaller than the 50 tooth 428 rear, I would guess it closely matches the 47 tooth 428 rear. The bolt patterns, center hole sizes, and thicknesses match. It took me a long time to locate the part numbers and I wasn't sure until I received the sprockets they definitely fit, I have several old ones around to compare them to as I've toasted 2 428 sets in the last year, and I'm on my 3rd now. Im hoping to get at least a year out of the 520 set. |
#24 |
Good info Jim.
#25 |
Yes, thank you for that information. I was contemplating upping to a 520 in the future as well. I have had good luck with 428H chains lasting a long time in the past even with my riding style.
For anybody considering this conversion, to match the venerable 17/45 you would want to run a 13/35 combination. For me to keep my 17/43 I can use a 13/33. I think I will hold off until my EK 428H o-ring wears out before I pull the trigger...mostly because it was nearly $80 lol. I honestly wouldn't worry about driveline loss. The weight difference between a 428h and a 520 chain per foot is pretty small. Even if it was 2% more loss, with a 15hp engine we are talking a quarter of a hp loss.
#26 |
I cut 5 links from a 112 link 520 chain to get a perfect fit with my 13/38 sprokets on the hawk. I Would not go bigger on the front sproket as it gets tighter in the case with a 520 chain, meaning you can get away with a larger front sproket with 428 than 520.
I was able to wiggle the cover right on over the fron sproket with the chain on. |
