#16 | |
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
#17 | |
#18 |
I attempted it with ac stick at low amperage.. wasn't happening, so off it went to the welding shop. He tried his clark mig 1st, no go.
I got the paperwork in the mail today, so I must have been one of the lucky ones (I ordered from that Manny feller). Heading out here in a few to adjust valves, change oil, and a couple other things. |
#19 |
It took its first breath! I have to let it cool down and do some minor carb adjustments. I have a slight pop/miss at idle, and it's slightly worse just off idle.. I probably just need to open the fuel mixture screw a touch more. I can just "blip" the throttle and it's very responsive, so I'm surely not off by much.
Still gotta adjust the chain, swap the wires for the front turn signals (might be confusing when the front signal is the opposite of the rear when flashing ![]() |
#20 |
Run it for a while. Take a few rides. It's mood will get better. Then do some more adjusting.
#22 |
After break in you will be amazed how they will handle grades in their powerband...careful out there!
#23 |
After you hit about 500 miles these bikes really smooth out.
#24 | |
![]() Last edited by JeremyC; 04-20-2017 at 03:19 AM. |
#25 |
I do want to thank all of you who have made various comments throughout all of the threads on here about what you run for carb jets. I did go ahead and play with the idle mixture screw yesterday, and it only needed another 1/8 to 1/4 turn out to get the popping at idle to go away, and the 120 main along with the needle clip one notch below center seems to be dead on. I'll know more when I run it a while and check the plug.
#26 |
I drained the forks and refilled with dexron VI (it was on the shelf) last night. I drained out 180ML and put the same back in. Should I add more, or does that sound about right? I'm thinking they could hold more, but how much?
#27 | |
200 ml's is what i got out of mine, you can adjust that a little depending on your preference just dont put too much in. whatever they had in min forks looked like burnt motor oil. |
#28 |
I drained 200ml out and put 210ml in. Made it nice and firm for off road trail riding. Before I changed it the forks would bottom out.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-21-2017 at 07:54 AM. |
#29 |
mine were the same way , they would bottom out thats why i changed it, i put in 200 ml of 10wt fork oil and it is good for me,
im not sure how much more you can put in without running the risk of blowing the seals out, i wouldnt go over 20ml just to be safe. |
#30 |
Same here! It was used break-in oil without a doubt. I'll ride it a while before I add more, but it does seem a bit spongy. Another option would be longer spacers to increase the pre-load on the springs, but how much is too much?
