Old 04-01-2017, 09:12 PM   #16
TJEli   TJEli is offline
Front shocks are installed. They fit perfectly (when the 10mm bushings are installed) and they are WAY better. I can compress them all the way by pushing the front end down. There is actually a little sag at static ride height. (Which is perfect). This is when them in their softest setting.
-Eli
1995 Kingquad 300
2015 Kingquad 750 PS
2017 Coolster 3150 DX2
Old 04-02-2017, 09:18 PM   #17
So is this a mandatory upgrade for all owners? Sure looks like a million. Hope it didn't cost it. I bet it is a night and day difference.
Looks great!
What other cool stuff are you going to add?
Old 04-03-2017, 03:51 PM   #18
Oh man.... I really like the looks of those and you say they actually work. I'm going to go and measure the Rhino.
Old 04-03-2017, 04:16 PM   #19
zackattack91   zackattack91 is offline
10mm bushings
awesome. did the 10mm bushings come with the shocks or did you just reuse the stock ones? notice how close the spring is to the A-arm bushing, thats where i was worried they wouldnt fit. but since they fit on yours they should fit on mine.
-Eli
2016 Coolster 3150-DX2
Old 04-03-2017, 08:38 PM   #20
Darth Racer's Avatar
Damn that looks nice. Not sure if this set would do it for the Rhino and a 200lb rider.. Might need one or two sizes up.
Old 04-08-2017, 11:07 PM   #21
Just a short update, I put the stock rear shock back on. This is a great setup. The stock rear shock works great with the new fronts. I had to reset the toe and camber but it rides great now.
-Eli
1995 Kingquad 300
Old 04-09-2017, 08:14 AM   #22
What was wrong with the new rear shock?
Old 04-10-2017, 09:35 AM   #23
Nothing was "wrong" with it. It just did not work as well as the stock rear shock. It was a tad shorter as well.
-Eli
1995 Kingquad 300
Old 04-10-2017, 11:06 AM   #24
I think I may be jumping on these as soon and Uncle's Sam and Jerry are paid here shortly.
I like how the spring rate and the gas is adjustable. It looks like one of the eyes may possibly be able to be lengthened also. That would be a bonus.
They may jack up snug enough to hold our girth. The Rhino rear shock is in desperate need also.
Old 04-10-2017, 12:18 PM   #25
beyondhonesty   beyondhonesty is offline
For the rhino 250, is there anyway to remove some of the fluid or change the weight of the stock fluid to gain some compliance?
I'm thinking to drill a hole and drain out the fluid...
12/2016 Rhino 250
Old 04-11-2017, 01:58 PM   #26
Just find out the stock size of the rhino shocks.
The shocks come in 300mm 320mm 340mm. Measurements are eye to eye. 300 is 12 inch, 320 is like 12.6 inch and 340 is a little over 13 inch. From eye to eye. The shocks are all over eBay and Amazon.
Old 04-11-2017, 05:36 PM   #27
Usually shocks are either disposable or rebuildable. It's not like a fork where you can drain fluid. That's why most shocks today are now gas charged. I just added some air to Q last weekend and it completely changed the attitude of the shock, including ride height.
Generally, with enough riding, they blow out and launch their fluid on their own.
Old 04-11-2017, 07:44 PM   #28
Slaphappy   Slaphappy is offline
I'm hoping if a Rhino owner pulls the trigger they let us know how it goes. I guess I'm a follower not a leader.
Old 04-21-2017, 06:24 PM   #29
Swapping bushings
So I got my new shocks. Same as the ones you got.
They come with 12mm bushings but they sent me 4 10mm bushings. How did you, or do you remove the 12mm ones and put the 10mm ones in? Help a coolster brother out. Thanks
-Eli
Old 04-21-2017, 08:13 PM   #30
07PSDCREW   07PSDCREW is offline
-Eli
Did you take the plastic off the front on purpose? Or was it missing? Mine was missing a seat.
