Old 03-23-2017, 02:48 PM   #16
Merlin   Merlin is offline
Thanks for the pics. Only time will tell how tall.
Bashan Blaze
Old 03-23-2017, 04:44 PM   #17
mjstef   mjstef is offline
Pull your cover, Lay a piece of plastic wrap across the valve assy., Take a ball of clay and put on the tallest part of the valve assy, Tighten cover down, Remove again and measure clay for clearance. It's possible a shorter cover will work.....
Old 01-06-2020, 12:41 PM   #18
hollow256   hollow256 is offline
I found these on amazon. A good bit cheaper than aliexpress for the oil filter model, but I hear the valve cover model is better as it cools the more critical head and top end parts better. Maybe some people will use both for maximum cooling?
Oil filter model no prime but only $60: https://amzn.to/37HAt61
Oil filter model with prime shipping: https://amzn.to/36AkiaE
Valve Cover model: https://amzn.to/2QsEDZv
