Old 01-15-2019, 10:40 PM   #16
Originally Posted by MIckeyNew View Post
I have a similar problem. Mine will not start in gear with the clutch pulled. I have tested the switch on the clutch and it is working. The wire to it are green and orange. I shorted them and it still would not start in gear. They go into the wiring harness on the handlebar. Where is the other end of that circuit? Where is the diode? Does it have a connection behind the headlight? 2017 Hawk 250.
the diode is located in the wire harness under the gas tank near the battery. It's a white rectangular plastic under the tape. You will see the bulge under the tape. Check the green harness connector near the engine just below the battery also .
2004 Honda ST 1300
Old 01-16-2019, 10:56 AM   #17
ben2go   ben2go is offline
Side stand switch?
Old 01-16-2019, 11:02 AM   #18
Originally Posted by ben2go View Post
Side stand switch?
Good call for most bikes but the Hawk doesn't come with a kick stand switch.
2004 Honda ST 1300
Old 01-17-2019, 11:30 AM   #19
That's what I though. I had to ask. I should have asked,"does the Hawk have a side stand switch?"
Old 02-26-2019, 08:52 PM   #20
MickeyNew   MickeyNew is offline
I communicated with the helpdesk at Killer and they told me the Hawk will only start in neutral, The referred to the owner's manual and said they talked to the factory. My response is BULL FEATHERS!!! I asked them to explain the switch on the clutch and the wires plugged into it.
I installed my new digital instrument cluster this weekend. Of course you have to remove the headlight and old cluster. Guess what I found? A single barrel connector unplugged. I found the mate and plugged them back together. When I finished the install and had the bike all put back together, I tried to start it in gear with the clutch pulled in. VIOLA!!!! So much for expert support. By the way I love Matt's digital cluster!!!
Old 02-27-2019, 12:49 AM   #21
NzBrakelathes's Avatar
You can ground the pink and then by pass the system.
Yeah the wiring behind the head light gets messy
Old 02-27-2019, 01:13 AM   #22
pete   pete is offline
pete's Avatar
Originally Posted by katflap View Post
I would check the clutch switch as well.
For the starter relay energizing circuit to complete it needs to ground through either the gear switch in the neutral position or the clutch switch closed ( lever pulled in).
My simplified wiring diag below , hmm, helpful or confusing, I can't decide
Attachment 8679
if there is a diode where you put it...
the starter button is feed with AC current
from the rectifier.. not DC from the battery as you have it drawn..
unless the start button is very big and can handle the DC amp draw..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 02-27-2019, 07:58 AM   #23
Glad you got it figured out. It's a good idea to go through the entire wire harness and check every connector and while your at it put some dielectric grease on those connectors to prevent corrosion in the future.
2004 Honda ST 1300
Old 02-27-2019, 09:54 AM   #24
bogieboy's Avatar
the start button on these is fed DC, because they actuate the solenoid that does the heavy current Pete, AC power would only be occurring when the bike is running...
