Old 02-01-2017, 06:23 PM   #16
Working_ZS   Working_ZS is offline
Was this through Taobao or CSC?
The prices are via CSC's website. I forgot to add in shipping, so add on another $100.00 to the grand total to be safe.
Old 02-01-2017, 09:13 PM   #17
jbfla   jbfla is offline
Originally Posted by Working_ZS View Post
Well, the "good" news is that it's a "China Bike". That means low cost parts. I've saved you the trouble, since you're probably not feeling like doing it yourself right now, of looking up the parts for repair:
Camshaft: 39.95
Cylinder Head Assembly: 179.95
Cylinder Block: 179.95
Cylinder Block Gasket: 5.95
Piston: 39.95
Piston Pin: 4.26
Piston Rings: 13.95
Oil Pumps: 22.90
Crank/connecting Rod Assembly: 140.00
Valve Cover Gasket: 0.79
Valve Cover Bolt: 0.2
Total: 627.85...
Thanks for the effort, ZS.
I did look up the price of a new engine: $2,480. US plus $115 shipping.
It's not worth it to put $2,600 into what would be a $2,600 used bike.
Maybe someone would like to buy a parts bike.
Hopefully it won't come to that.
jb
2014 XT 250........
Old 02-01-2017, 10:07 PM   #18
I took a closer look today.
You wouldn't think that you would lose that much oil from an open valve cover.
This is what came out when I drained the crankcase:
The oil filters had only a few specs of silver and the magnetic drain plug none....maybe I'll be lucky:
I replaced the filters and drain plug, and filled the crankcase with new oil.
Then removed the spark plug and squirted motor oil into the spark plug hole, and tried turning the engine over by hand.
It turned over....
Then decided to check the valve clearances:
Intakes were at .005" and .008" Reset them to .003"
The exhaust valve clearances were both at .003+" ...not as much drag on the feeler gauge as I would like but left them alone.
When I went to reinstall the valve covers, I found a clue as to what may have happened.
One of the bolts on the front valve cover had slivers of aluminum in the thread.
And when I tried to screw it back in place, found that the threads in the cylinder head hole where stripped...
Then retrieved another M6x20 bolt to replace the missing bolt for the rear cover only to find that hole also had stripped threads.
The threaded holes were not stripped when I checked the valves 500 miles ago.
Those slivers of aluminum on the valve cover bolt brought "galling" to mind.
galling
I hadn't encountered this in years, but basically what happens is that under pressure, the aluminum threads in the cylinder head bond to the steel threads of the bolt.
When the bolt is removed the aluminum comes along, and the hole is stripped.
This is only speculation as to what happened.
Regardless, I now have two holes to fix before I can refasten the valve covers.
Retap with a larger bolt? Heli-coil? Time-sert?
That's for another day.
jb
2014 XT 250........
Old 02-01-2017, 10:30 PM   #19
Thus the valve cover Jammed the rocker arm causing the seize when you tried to turn it over with the electric starter.
This is looking better but still a bummer. Hope the thread issues works out. This stuff can be tricky. Make sure you hold your mouth just right and pray.
When you get it fired, stick that long screwdriver head in your ear and start probing around.
I think its gona be alright, i know the mechanic and he's good.
Old 02-01-2017, 10:40 PM   #20
Mabey you could convert it to those high quality/strength stud bolts if you have room to lift the cover free of the studs. . Then those studs would not have to be budged again.Just a thought not sure
Old 02-01-2017, 11:45 PM   #21
pete   pete is offline
pete's Avatar
Originally Posted by 2LZ;242030
Another question. Does the injection, etc...shut down automatically when oil pressure gets too low to save itself?
LOL... really!
It would be a mungle of a thing to start.... crank on the starter till oil
pressure is high enough...
And imagine after a oil/filter change when everything is empty...
that would be a 2 battrey job...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 02-02-2017, 12:49 AM   #22
rtking   rtking is offline
jb
JB,
Great that the motor turns freely! Hopefully no cylinder wall scoring or ring damage. But likely it'll be just fine, especially since you saw no metal in the oil.
While it might be tempting to just retap the threads for a larger bolt, I think that if you're correct about the galling, then I'd opt for the Helicoil or Time-sert. Those are permanent solutions and you'll never run into the galling issue again.
Old 02-02-2017, 01:47 AM   #23
pete's Avatar
As for the striped 6mm threads..
just retap them with 1/4" unc...
no drilling just run the tap into the
striped 6mm hole...
It really is that simple...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 02-02-2017, 09:59 AM   #24
All are valid repair methods. It really depends on what you have at hand. If you happen to have some Helicoils that fit, use those. Same for the Time-Serts. Neither is going to be better than the other here. We're talking around 5-10 ft/lbs of torque max for a M6x1.0 bolt, depending upon grade, in this application. Cost-wise, Time-Sert kits will set you back more than the Helicoil kits. Pete's suggestion of tapping to 1/4" UNC would work as well, but then you're left with two bastard bolts in the engine. I usually try to avoid a situation like that. Keep it metric or american, not a mix.
BlackBike's suggestion to install studs is interesting. It would solve any future thread galling in the existing, un-stripped holes for sure, but I'm uncertain about clearance on the exhaust side of the engine to remove the valve cover. I would probably stay with bolts if it were my bike and I planned on selling it in the near future.
Old 02-02-2017, 10:43 AM   #25
Originally Posted by pete View Post
LOL... really!
Yes, really. Many fuel injected vehicles have safeguards in place so they don't grenade themselves. Both oil pressure and voltage.
Old 02-02-2017, 11:48 AM   #26
bogieboy's Avatar
Honda generator/compressor/lawnmower engines do as well...
Old 02-02-2017, 01:17 PM   #27
I was think this too, also don't outboard engines have this? Just depends on how electronically complex.
He said it started losing power, is there a oil pressure sensor on this rx3? Wouldn't be surprised, then when it goes out of spec, software excuses "limp mode" this is common strategy in auto's
Katflap... oil sensor?
Old 02-02-2017, 03:58 PM   #28
katflap   katflap is offline
katflap's Avatar
Hmm, let me see..........
Name:  kat on laptop.JPG
Nope, sorry , no oil sensor on the RX3
Old 02-02-2017, 07:07 PM   #29
madsocial   madsocial is offline
madsocial's Avatar
JB, really sorry to hear this has happened. As a Harley owner, I know a thing or two about screws randomly missing. I can't begin to tell you. I just got in the habit of inspecting them all before I ride. It's a bit time consuming, but when you have lost as many as I have it's worth the time.
My husband said the same thing as Pete, btw. Once you give yourself the time to get back to it.
On another note, we'll be in West Palm Beach for month in March. Are you near there?
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 02-03-2017, 10:04 PM   #30
Attachment 8414
thanks, i have been having issues with the site . can't get it to update correctly and spotty log on.
cool cat, black and whites have the best temperament in my opinion.
