05-24-2017, 03:02 PM | #16 |
Thanks for the idea! Any recommendations on a place to get parts that will actually fit? I am having a hard time finding anything specifically for this bike.
05-24-2017, 03:08 PM | #17 |
Anything engine related you can use the Hawk tuning guides for as it is the same motor. They come jetted very lean from the factory and need some tuning to run properly. There are a lot of guides and info on how to do this, and it is VERY easy. Also, as mentioned in this thread, the valve adjustments are also important to do, and also very easy. Watch the videos posted in this thread and do a bit of reading on Hawk carb setups/tuning, and you should be fine. It is all easily doable for even a novice, and a great way to learn. If you are still unsure, find a buddy or a relative that is familiar with this kind of work so they can help you/show you how it is done. You got this!
05-24-2017, 03:24 PM | #18 | |
05-24-2017, 06:20 PM | #19 |
When I first got my Magician I couldn't get it too stay running either. I kept fighting with the carburetor thinking that was the problem but to no avail. One day I finally took everyone's advice and adjusted the valves and it ran perfectly after that. They were so ungodly tight I couldn't believe it ran at all. So seriously adjust your valves. Your carburetor is probably fine if you have the mixture screw set out about 1.5 turns. Adjust your valves. If it doesn't sound like a sewing machine then it isn't right.
05-24-2017, 06:29 PM | #20 |
bottom mixture screw out 1.5 to 2 turns.
05-30-2017, 11:45 AM | #21 |
Thanks all! I had a friend come over and help me with adjusting the idle screw. It seems like it is running better now! I am probably still going to do the valve adjustment, but later.
I am going to try and post a video of my Magician running, so you all can hear it. Thanks! |
05-30-2017, 11:59 AM | #22 | |
05-30-2017, 02:24 PM | #23 |
The Magician uses a different style of shifter setup from the Hawk. It's a stud mount pivot on the peg assembly with a linkage to a shifter arm on the motor.
