Old 01-07-2017, 08:31 PM   #16
In Human's post- (& can guess from engine model 196 163FML | 229 167FMM (often in alternator cover's bottom)
Look for those two engine codes (163 FML or 167 FMM) stamped in the cover or engine case somewhere. Its a ZONG so I'm sure its stamped in there. That will tell you what the displacement is.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 01-07-2017, 09:18 PM   #17
Dakados   Dakados is offline
Dakados's Avatar
Originally Posted by Bruce's View Post
http://www.quadnet.ca/en/articles/9548/
If that doesn't show up ,google Gio beast .
The unit there is not the same. Shown is a teen on the machine and his knees up to his chest. The unit I have fits me. I'm 47, 5'10" narrow build, but my knees are level while sitting on the quad. Wheel lugs are back threaded so bolts, not nuts. Tires are very small, front clearance is over a foot in the middle, read skid guard is inches off the ground. The body is easily explained by a manufacturing year difference, the size is not.
The quad I have is a full size quad just two wheel drive. I have had in the past a Honda trike and a Big Bear more recently last 20 years.
Regards,
Dak
Old 01-07-2017, 09:30 PM   #18
Bruce's   Bruce's is offline
I have owned a few Gio beast 200 quads ,they also made a smaller beast but I cannot remember the size ,it might be 110 cc . I am a little feller ,only 6'5" ,245 lb ,and I found the beast too small for me ,but I could ride it ,kind of like an old 185 Honda trike .If yours is not a beast ,I would be very surprised as it looks just like one .I guess we should ask ,do you live in Canada ?as far as I know ,that is the only place you can buy a Gio ,so if you don't live here you probably have something else .
Old 01-07-2017, 09:39 PM   #19
http://www.atvedmonton.com/atvedmonton/images/Beast/
Might be a few better pictures here for you to compare .I just looked at your pictures again ,and I am pretty darn certain you have a beast .Gio did change their bikes a little from time to time so some features might be a little different .
Old 01-07-2017, 09:56 PM   #20
Dakados's Avatar
Excellent view for sure Bruce, thank you!
It even says full size in the specs there, so what was that kid riding? lol
6'5" 200+lbs... Your new nick is tiny! lol I'm around 165lbs at 5'10" my wife figures I'm chunky. hahaha.
Anyways, we're kinna' on hold until I can uncover the quad to look again at the block.
Regards,
Dak
Old 01-07-2017, 10:04 PM   #21
It really is not full sized ,I have two Polaris trail boss 335's and they are huge compared to the beast ,and they are not very big quads
Old 01-07-2017, 11:11 PM   #22
Something to shoot for
Old 01-08-2017, 07:15 PM   #23
Originally Posted by Dakados View Post
I'm loving the posts on this forum so I'm not leaving even if nobody can help.
Good attitude!
As Humanbeing and Letsride indicated, there is a stamped number on the side of the motor near the gearshift that we can interpret as displacement. Gotta get down low to see it.
The displacement is most likely to be 200, but it could also be 230. Both engines use the same electrical system and carb. As FLBoy said, a 30mm Mikuni will do the trick, and you can have one shipped to your door for around $50.00 CAD.
In the meantime, check out the Gio Beast 200 sticky here: http://www.chinariders.net/showthread.php?t=8436
Old 01-08-2017, 08:07 PM   #24
Darth Racer's Avatar
If you can find the numbers stamped on the crankcase this chart will help you decipher them.
Old 01-10-2017, 12:15 AM   #25
Dakados's Avatar
Regards,
Dak
So, we're still hanging around -27, working on a quad is not high on the list.
Adult machine just means you're not choking on your knee and that's two completely different types of quad.
The chart is fantastic! Thank you very much... All of you rawk!
Yeah, you're showing a gorgeous bike. lol. Mine will be, at best, a Frankenstein experiment. I will keep the board updated.
Regards,
Dak
Old 01-10-2017, 05:36 PM   #26
You are probably better off not working on it at those temps. Plastic gets real brittle when that cold. Wires sometimes will snap too.
Old 01-11-2017, 05:46 PM   #27
Dakados's Avatar
(Images too large, and of no import, removing them)
I may be on my own with this one... Stuck the phone under the cover a minute to get some engine snaps...
Left at full rez for now in case someone thinks they can find something.
Regards,
Dak
Old 01-11-2017, 07:28 PM   #28
Keep going down on the left side until you find the oil screen cover. It's got a hex head on it. To the left or right you will find the info listed in the chart to determine engine size.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 01-11-2017, 07:59 PM   #29
This pic was just posted in another thread ... yours should look similar.. the pic might help you find the location easier.
Old 01-11-2017, 10:55 PM   #30
Great job, Darth. As a side note, when cleaning the screen behind the cover, be aware the cover flange is very thin. It's very easily damaged if put back on too tight.
2016 Rhino 250
2016 Tao Tao 125D
