#17 | |
#18 |
LOL that's one way to look at it. I had it running for about 15 minutes, shut it off, and back to the same thing again. Runs at most 30 seconds if I keep playing with the throttle, even then it doesn't run smoothly. It acts almost like there's a fuel problem but I'm positive it's an electrical issue. I replaced the spark plug in both ATV's with NGK C7HSA when I changed the oil the second time.
#19 |
I read where they put some kind of gel packs in the carburetors for shipping that sometimes don't dissolve they way they're meant to. So I took the carb off hoping to investigate/clean it. Nope. They sealed up the bolts. I ordered new cdi, voltage regulator, coil, and carburetor. Whatever I don't need now, I'll have a spare for later. I know for a fact I need the cdi though. Tomorrow I'll attempt to take the carb apart, but I imagine I'll end up tearing it up trying to remove the bowl. Haven't been able to contact the vendor/dealer yet. Guess they're still closed for the holidays. The saga continues....
#20 |
If this was my problem, I would swap those parts and verify the issue since I have another unit before I ordered parts. also if that intake valve is in lock down it not going to want to start or run for shit.
Good luck.
#21 | |
#22 | |
#23 |
I swapped everything except the carburetor. My tests indicated that the CDI was bad. Swapping it got it to run but not stay running. I swapped the other electrical components just for "fun", but they didn't make any difference, nor did I expect them to. Those parts test fine. I had to go back to work today so that will prevent me from swapping the carb until the new one comes in on Thursday.
#24 |
Yes, I read all kinds of good things about these bikes, so I'm still hopeful once I get over this initial bump in the road they will prove to be just as good.
#25 | |
#26 | |
![]() Quote:
#27 | |
#28 | |
#30 |
Mannnnnn, it better not be! But you're probably right!
