Old 11-04-2016, 05:04 PM   #16
pete   pete is offline
pete's Avatar
took the Berg for it's first ride....
think I have become a lazy rider since
owning the TTR.... The Burg requires
you to be very aggressive to make it work..
At 94kgs you can change direction at will
move yer weight back it lifts the front.
Yer don't have to slow down for small logs
dithes etc
I havn't played with the suspension yet and it
just floats over anything... no jarring coming
though the bars from the front end..
I did put it down... I stoped on uneven ground
couldn't get a footing.. over we went... seat
hight is a bit high for me... when I get the sags
set it will drop 100mm when I'm seated..
rear brake has no feel.... off or locked rear wheel
the motor stalls very easy...locking rear brake makes
it even worse...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 11-04-2016, 06:10 PM   #17
Merlin   Merlin is offline
I bet it will get better as everything brakes in.
Old 11-04-2016, 06:25 PM   #18
pete's Avatar
yes.. I will give it another easy ride... then I can realy start ringing it's neck...
I was running oily mix so that possably not helping the stalling..
there a couple tricks to sort the rear brake... grind grooves though the pads
to reduce surface area or interduce air into the brake system.
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
