Thread Tools Display Modes
Old 10-20-2016, 02:33 AM   #1
'16 TT250   '16 TT250 is offline
My statement of "bad mix" is strictly from a basic electromotive force standpoint. Sometimes a bad mix is the best available option.
Old 10-20-2016, 12:49 AM   #2
I agree with using anti-seize on the SS studs.
Any progress on your project?
Old 10-22-2016, 12:54 AM   #3
Landsvw   Landsvw is offline
Landsvw's Avatar
Did some research on the 5.4 exhaust manifold studs issue. Looks like, the original studs are too small and soft. So the expansion and contraction of the manifolds breaks them off. And then an exhaust leak develops. Thus, stainless, or, at least harder, studs. Some people recommend loosening and re tightening them every so often too, once replaced. It basically resets them. So, that explains why I had at least 1 shear immediately with almost no pressure. Was already cracked. And, these ones even look good, with little rust. Not sure if stainless will help, but these stainless ones have no shoulder going into the heads so may have a bit more flex? Or ability to resist the stretch? I dunno. In 30k miles I'll know something. Lol. That's the mileage that they start to break then leak.
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 10-22-2016, 09:46 AM   #4
katoranger's Avatar
When I pulled my V10 I had about 5 shear off. I will still able to remove the broken parts easily with a vise grip from the heads. The heads are running around on another V10 now.
Old 10-22-2016, 03:50 PM   #5
Landsvw's Avatar
Head one off... what a pain...
1975 Corvette
2017 Chevy Bolt
Old 10-22-2016, 05:41 PM   #6
Landsvw's Avatar
Passenger side head is ruined. Carnage pictures to follow
1975 Corvette
2017 Chevy Bolt
Old 10-22-2016, 05:43 PM   #7
Landsvw's Avatar
1975 Corvette
2017 Chevy Bolt
Old 10-22-2016, 05:44 PM   #8
Landsvw's Avatar
Driver side head is fine. Passenger side head is ruined. Engine is still stuck. I'm going to raise it up in a few minutes and pull the pan.
1975 Corvette
2017 Chevy Bolt
Old 10-22-2016, 10:00 PM   #9
Landsvw's Avatar
Rod bearings 1 and 2 seized. Evidently, the timing chain guides disintegrated and the small particles plugged the oil pickup. This starved the engine of oil. 1 head, 1 crank and 2 rods - toast. The engine could have been rebuilt tho, but since I have the good one, I'm just going to use it. I was able to loosen the bolts on the 2 rods, push the pistons out the top and get the engine to turn over. 8 more bolts and I should have the engine out of the bay. Whew!
Then I went road hunting for deer. And ate dinner. So, until next time...
1975 Corvette
2017 Chevy Bolt
Old 10-24-2016, 11:25 AM   #10
Do you plan to replace the chain and guides on your new motor?
Old 10-24-2016, 08:04 PM   #11
Landsvw's Avatar
No, I pulled pan and was clean and shiny. Will run it as it sits. Nothing is breaking apart, so no need to mess with it. Not sure why the guides go bad, but
I'll bet it's to do with non frequent oil changes. Dirty oil, wear, overheating etc. my Jeep was the same way at 135k miles. Pieces of the guides in the pan, a blown headgasket, etc. no oil starvation tho, so crank and rods we're fine.
1975 Corvette
2017 Chevy Bolt
Old 10-23-2016, 09:17 AM   #12
katoranger's Avatar
I had a V10 that I believe hydrolocked from a bad head gasket. Two rods thru the block. Took us awhile to get it out of the van too. I had to pull the intake so that my shop crane would clear the firewall.
Old 10-25-2016, 11:07 AM   #13
I can understand not messing with it if it looks clean. That said, it's easier to replace the chain and guides while it's out of the truck.
Old 10-25-2016, 09:20 PM   #14
Landsvw's Avatar
That's certainly true!
It's a roll the dice kinda deal, and I guess I'll take the chance lol. It may come back to get me, but at the same time, it may go another 100k miles and no probs.
1975 Corvette
2017 Chevy Bolt
Old 10-27-2016, 07:59 PM   #15
Landsvw's Avatar
Old engine is out and hanging on a chain!
1975 Corvette
2017 Chevy Bolt
