Old 10-15-2016, 08:28 PM   #16
Vibrations will be greatly reduced when you decide on a good street sprocket setup. 17/45 is a good place to start. Hopefully the hub is the same as the '80 XL185 Honda like on the Hawk and TT250--numerous rear sprockets to choose from.
Old 10-15-2016, 09:17 PM   #17
motorcyclelove   motorcyclelove is offline
I'm pretty sure I read on here somewhere the storm comes with 17 50 sprockets. Barlow correct me if I'm wrong...
Old 10-15-2016, 11:19 PM   #18
lprewitt   lprewitt is offline
I think it is 17/46. Mine has "B46T" stamped on the rear sprocket. I did a search on this forum and did find that someone has recommended 17/43.
Old 10-16-2016, 12:29 AM   #19
Ariel Red Hunter's Avatar
Originally Posted by lprewitt View Post
Thanks for the quick recommendations. That sounds like the way to go. I put about 80 miles on the bike today. Ran fine but it sure is tight...needing a breakin. The gearing is a little low for me....even for county road use. Ran it mostly at 30 to 40 mph. The vibration really comes in at about 45mph in 5th, 35mph in 4th....I'm guessing around 3000 to 3500 rpm. I suppose this is normal. Don't remember my Honda 200 being quite that buzzy. The engine sounds OK. I can hear the valve tappit tick....don't think the valves are adjusted too tight but will check them later after a few miles. I thought this bike would be less "buzzy" with the counter-balanced engine. Does this seem normal for a Storm?
Make sure the motor mount bolts are good and tight. Loose motor mount bolts really make whatever vibration there is much worse.
Old 10-16-2016, 12:33 PM   #20
Thanks. I will definitely check that. Does anyone know the torque settings for those bolts. I sure wouldn't want to strip them.
Old 10-16-2016, 03:57 PM   #21
Grip up (or choak up as they say) on the ratchet drive and tighten hard. This won't allow you to tighten too much. Then give it another short turn farther out on the ratchet handle. No , not scientific and it you want specifics, ain't gonna happen. Is it close enough, you bet. This being said , if you are a arm wrestling champ, perhaps you should find a torque wrench with proper specs.
I think arh has alluded to a similar idea also.
Old 10-16-2016, 04:59 PM   #22
I like it!! So, the engine mount bolts were "tight" but the little chrome heat should was only "snug".....1 1/2 turns more and most of the buzz is gone.
Old 10-16-2016, 05:06 PM   #23
The buzzy heat shield.
Should have looked there first. My old 1968 Honda 305 scrambler was notorious for that buzz with its heat shield.
Old 10-16-2016, 05:14 PM   #24
Now go try on some dirt!
Old 10-24-2016, 03:36 AM   #25
BARLOW   BARLOW is offline
BARLOW's Avatar
17/45 sprockets
Old 10-24-2016, 03:43 AM   #26
BARLOW's Avatar
Barlow--did you feel you needed to change the carb like most of the Hawk 250 owners, or was it just for the sake of improvement? In other words, was the stock carb fine, or were there shortcomings like the Hawk?
it did seem to be lacking power with the stock carb, but it was still new ... it was also a bit harder to get started, and ran way to lean on the top end ... with the 40/115 it is now a tad rich, but i thought i would have a better pipe and filter already and planned ahead for that ... the bike leaves me a bit puzzled though, when you get up around 6500 rpm it just seems to stop pulling in 5th as if it lacking the power to pull ... the odd part (to me anyway), is that with or without my wife on it, it is the same
Old 10-24-2016, 11:58 PM   #27
Originally Posted by BARLOW View Post
17/45 sprockets
Mc.love... I had the 17/50 sprockets on the blaze bike, went to 43 rear but it kills top end (about same performance or worse) , I think it's too low for the hp. May get a 47 rear sprocket and quit
Old 10-25-2016, 10:47 PM   #28
ben2go   ben2go is offline
The head and cam profile can't flow enough air to build top end power.These engines are like tractors,they make their best power down low and pull well off the line with good gearing.
Old 10-26-2016, 09:50 AM   #29
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
Well damn, I was feeling pretty good about ole Swamp Thing then had to come across this.... That thing is too damn purty!
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 10-27-2016, 12:59 AM   #30
Attachment 7624
Sell the swamp, except order the brozz . Better yet, run the wheels off swamp and order a new rx4 with me in January 2018
missouri, roketa, storm
