Old 08-13-2021, 09:15 PM   #16
Working_ZS   Working_ZS is offline
Originally Posted by ChopperCharles View Post
I already waved an unlit propane torch around the intake, with no change in behavior. One of those big brush-clearing torches. It's enough propane to stop an EX500 motor in under a second when waved around the airbox intake. And nothing budged on my RX3.
Charles.
Then you can be reasonably sure that you don't have a vacuum leak; knowing this you will be able to have confidence in evaluating what the diagnostic software tells you via the DTC PID values.
In relation to testing the sensors specifically; if you are at idle, which creates high manifold vacuum, yet your MAP sensor has a high voltage reading - indicating low vacuum, like an engine running under load; then you have a bad MAP sensor. The situation is similar with the O2 sensor - give the throttle a couple of quick snaps while watching the O2 sensor voltage readings - they should vary up and down. If yours don't budge, then the O2 is bad.
Old 08-15-2021, 10:51 AM   #17
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
Cool. I've got the diagnostic parts in last night, and will install the software and mess with it today.
Charles.
Old 08-29-2021, 12:04 PM   #18
katflap   katflap is offline
katflap's Avatar
In the first post of this thread,
I have renewed the link for the repair manual that accompanies my fault code look up program.
Perhaps this might help in making a diagnosis.
Regards
Old 03-31-2024, 05:51 AM   #19
Trololo   Trololo is offline
Charles.
Hello, tell me what software and what cable is needed to diagnose and adjust the motorcycle? Where to take the program?
