Old 07-06-2016, 11:28 AM   #16
Mudflap   Mudflap is offline
I would run it until it quit again then quickly reach down and shut off the petcock. Then open the drain screw on the float bowl and see if an ounce or two of gas drains out. If it does, fuel flow to the carb is OK.
Then pull the spark plug and check for spark.
Then put thumb over the plug hole, hold tight, crank engine, see if air escapes past your thumb.
Old 07-06-2016, 12:37 PM   #17
pcspecialist   pcspecialist is offline
What replacement CDI do you recommend?
Old 07-06-2016, 01:39 PM   #18
It depends on what CDI you have. AC or DC. Look at the connector and buy one with a like connector configuration. It should also be marked.
Here's an example of the many available on Amazon.
https://www.amazon.com/4-stroke-Hori...+dirt+bike+cdi
Old 07-06-2016, 02:33 PM   #19
It has a 4pin and 2pin connector (both rounded). I asked for recommendations because all the ones I have seen have poor reviews.
Old 07-06-2016, 02:49 PM   #20
w0ss   w0ss is offline
I asked the same previously. I wanted to buy a known good CDI. But never heard about one. I ended up buying a 10$ one that advances the timing. I don't have it yet but fingers crossed.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-06-2016, 03:44 PM   #21
Good luck with the "quality" CDI chase. My particular luck has been it didn't really matter. I have a cheap-o (free to me) in my X-Moto now that's worked fine for years. It's probably because I have a known-good used cheap-o in back stock as a scare crow.
w0ss, let us know what you think about the adjustable CDI. I've always wondered about them but haven't heard anything good or bad. I think Humanbeing has commented on them in the past.
Old 07-06-2016, 05:17 PM   #22
I just ordered a KITACO brand CDI. If it is the real thing or a good clone, it has been dyno proven (3rd party) to improve mid-range power. I am sceptical, but, it's worth a try. If it works at all, it will at least be a good backup.
http://www.aliexpress.com/snapshot/7862357071.html
Old 02-19-2017, 04:06 PM   #23
LunaTech   LunaTech is offline
LunaTech's Avatar
Hey Sport Rider I know this thread is old but my Hawk is acting similar. What finally fixed your problem?
