07-08-2016, 01:46 PM | #17 |
Now for sprockets, this will work? I wanted to ask before I order...
Rear 45T https://www.amazon.com/dp/B0068O5W3M Front 17T https://www.amazon.com/JT-Sprockets-...ilpage_o09_s00 Do I need both? I would like to get more out of the bike for highway (65mph) I've seen you guys recommend it, just wanted to make sure before purchase. This gives the bike a 2.65/1 ratio Thanks. |
07-08-2016, 03:28 PM | #18 |
http://www.ebay.com/itm/NEW-JT-REAR-...xUvE9X&vxp=mtr
You didn't notice the stock level on Amazon. The front sprocket would be JTF259.17. I went 16/44wich is about the same.
07-08-2016, 04:16 PM | #19 | |
Thanks hertz, I'll probably do the 16/44 due to availability http://www.ebay.com/itm/191486938944 http://www.ebay.com/itm/262513993190 |
07-08-2016, 04:23 PM | #20 |
For reference:
The exhaust header is a M8 x 1.25 nut The carb header is a M6 x 1.00 nut |
07-08-2016, 04:54 PM | #21 |
You must have read my mind! I was about to pull one of each off to take to the hardware store for replacements.
07-08-2016, 05:11 PM | #22 |
I got you bud! Saved you 30mins at lowes haha
07-10-2016, 01:41 PM | #23 |
Thoughts on a Adjustable CDI to advance timing?
http://www.ebay.com/itm/162012556646...%3AMEBIDX%3AIT |
07-10-2016, 01:51 PM | #24 | |
http://www.ebay.com/itm/281856019387...%3AMEBIDX%3AIT looks identical but only $9. I installed it a week ago and am waiting a few more rides before I decide if it's staying. It seems to give it more in the mid range but it is a tad bit harder to start.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust. |
07-10-2016, 01:56 PM | #25 | |
http://www.aliexpress.com/snapshot/7...76610299303218 |
07-10-2016, 02:08 PM | #26 |
Thanks guys, will do. Has any one changed out their clutch/brake levers? I was thinking of getting a universal kit, but I'd much rather just replace the lever.
http://www.ebay.com/itm/182009317036?var=482488924316 I did some digging and the pivot bolts are the same as a Kawasaki dirt bike lever. These are OEM for our levers. http://www.ebay.com/itm/191458926873 |
07-11-2016, 11:47 PM | #27 |
So I fab'd my new tail light bracket. This tail light has integrated turn signals. I just made a card board mock up and then cut some 22G steel then bent it. I drilled two holes for the wiring harness. I also had to cut the weld on the old mounting point for the old tail light and bent it down to fit my bracket. I used 4 metal screws and drilled through the bracket and frame.
I had an issue, all lights work except the parking lights or the night lights. I tried connecting the new (only one wire for the parking lights) tail light to the old tail light parking light wire and nothing, I also tried the license plate light and nothing. However, when I connect that parking light wire straight to the battery it worked perfectly. Anyone have any ideas? I tried a resistor but it still didn't work. I don't understand. I also tested the parking light and license plate light wire, that comes from the bike, with a volt meter and it's getting 12.3V. So I'm lost. Here's some pics of how it came out. The finished product is looks better. I didn't take pics because I'm exhausted lol. Note: Brake light and turn signal lights work perfectly. So I'm super lost. Thanks guys. |
07-12-2016, 01:06 AM | #28 |
I installed one of these. I had trouble finding out which one was negative as I remember it.
07-12-2016, 09:47 AM | #30 |
Even so, it was trippy. Thanks for the contribution.
